Old 09-25-2022, 08:56 PM   #1
jdpalmer
jdpalmer's Avatar
Default Drooping door handles
Seems like all four door handles droop down when doors are latched. Seems they all did at same time has anyone had this problem and replaced the springs. They are expensive in all catalogs
Jimmy Palmer
jdpalmer is offline   Reply With Quote
Old 09-25-2022, 09:20 PM   #2
dave in australia
Default Re: Drooping door handles
Do they droop when the door is open?
dave in australia is offline   Reply With Quote
Old 09-26-2022, 05:13 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Not all do, -but restoring latches and window glass regulators is just part of doing a true restoration. Unfortunately it is an often over-looked part of the restoration.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-26-2022, 09:55 AM   #4
kbinde2
kbinde2's Avatar
As Brent has said, restoration/replacement of component of the "working" parts may be a solution, vs. new handles.. driver side door on my coupe shows more wear (patina) than the passenger side. Same has been mentioned in cars leaning to the driver side in previous posts. Over time these doors were opened and shut more than we'll ever use them.! kb
kbinde2 is offline   Reply With Quote
Old 09-26-2022, 10:35 AM   #5
Oldbluoval
Oldbluoval's Avatar
The springs 99 out of 100 are not the problem. It’s wear in the latch.
Most often the drivers handle is the worse as it’s used more.
A restoration of latches requires disassemble and taking care of the wear points.
Not easy/not cheap.
Oldbluoval is offline   Reply With Quote
