Old 05-11-2016, 11:10 AM   #1
Tod
Default Aluminum block pour.
Tomorrow we will pour the first aluminum block sample. Finally! I might video the pour and shakeout, even if the results aren't perfect.
Tod
Tod is offline   Reply With Quote
Old 05-11-2016, 11:37 AM   #2
Juggler
Juggler's Avatar
Default Re: Aluminum block pour.
Video will be interesting thanks
Juggler is offline   Reply With Quote
Old 05-11-2016, 12:22 PM   #3
noboD
What is the calculated weight difference?
noboD is offline   Reply With Quote
Old 05-11-2016, 12:27 PM   #4
hardtimes
hardtimes's Avatar
Tod
Hey Tod,
Best of luck with that pour !
Is this 'first' alum going to be regular A/B style design...or the one discussed (easier?) where the OHV Head would be used !
hardtimes is offline   Reply With Quote
Old 05-11-2016, 01:33 PM   #5
mshmodela
mshmodela's Avatar
Best wishes for a great pour --look forward to the video... these 85+ year old blocks ain't going to last forever!
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-11-2016, 02:09 PM   #6
fastroadster
Looking forward to video................Good Luck
fastroadster is offline   Reply With Quote
Old 05-11-2016, 03:27 PM   #7
Tod
Aluminum is about 1/3 the weigh of iron. My raw iron blocks are 130lbs. so the aluminum should be cleaned up at 46lbs.
Tod
Old 05-11-2016, 03:29 PM   #8
Tod
Originally Posted by hardtimes View Post
Hey Tod,
This first one is a 3 main B tailed block. The next one will probably be a 5 main with an A tail. But if someone wants a 5 main B tail I could do that.
Tod
Old 05-11-2016, 05:44 PM   #9
noboD
Thanks, I too would like to see video. Sounds like an interesting project.
Old 05-11-2016, 06:31 PM   #10
GregLast
GregLast's Avatar
Long time coming! Excited to see what comes of it.
GregLast is offline   Reply With Quote
Old 05-11-2016, 06:59 PM   #11
Model A Man
Model A Man's Avatar
will look forward to the video as I have no clue how that kind of work is done. You must get a great deal of satisfaction and joy to see this come full circle. Best of luck to you and Thank you for sharing
Model A Man is offline   Reply With Quote
Old 05-11-2016, 07:06 PM   #12
C26Pinelake
You have a lot of supporters. Good luck Tod! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-11-2016, 07:11 PM   #13
MikeK
MikeK's Avatar
356?
MikeK is offline   Reply With Quote
Old 05-11-2016, 07:12 PM   #14
Tod
The video won't supply a lot of info in that regard because there are some things that I try not to share.
Tod
Old 05-11-2016, 07:13 PM   #15
Tod
Originally Posted by MikeK View Post
356?
Yep. T6.
Tod
Old 05-12-2016, 05:38 AM   #16
waxhead
waxhead's Avatar
Good luck, I hope it goes according to plan.
waxhead is offline   Reply With Quote
Old 05-12-2016, 06:33 AM   #17
George Miller
George Miller's Avatar
Are you going to use steel cylinder sleeves?
George Miller is offline   Reply With Quote
Old 05-12-2016, 06:51 AM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
I was wondering about the sleeves also, and are they installed at the time of the pour, or are they always installed after the machine work?
Old 05-12-2016, 07:01 AM   #19
Tod
Actually, ductile iron sleeves are used. They are inserted after all the machining is finished. A slight crush/interference fit of a couple thousandths is aimed at. The block is then heated to allow the sleeve to slide in and when the block cools back down it tightens around the sleeve.
Tod
Old 05-12-2016, 07:35 AM   #20
George Miller
Tod
Sounds good. I like the idea of the 5 main. Is some one making crankshafts for a 5 main. Thanks
