Old 06-23-2010, 11:29 PM   #1
dean from bozeman
dean from bozeman's Avatar
Default Help: Super Winfield head
Howdy,
I have a Super Winfield head. Cast aluminum, I imagine. It says "Pat. Pend".
I got it a few years back in a collection of parts. I may offer it to a friend but I need to know a few things about it. Any information would help, including how it enhances performance of an A's engine, price, etc.
Thanks.
Dean
dean from bozeman is offline   Reply With Quote
Old 06-24-2010, 08:50 PM   #2
jetmek
Default Re: Help: Super Winfield head
thats likey at least 7-1 cr maybe more. if no flycut over the pistons make sure to "clay" the head to check for clearance they can be had new for about 300
jetmek is offline   Reply With Quote
Old 06-24-2010, 10:39 PM   #3
fordcragar
fordcragar's Avatar
Originally Posted by jetmek View Post
............................ they can be had new for about 300
Just out of curiosity, where could you buy one for about $300?
fordcragar is offline   Reply With Quote
Old 06-24-2010, 11:53 PM   #4
Kirby1374
Kirby1374's Avatar
I've seen regular winfield repops on red's headers but not super winfields.....
Kirby1374 is offline   Reply With Quote
Old 06-25-2010, 12:06 AM   #5
Strever
Strever's Avatar
actually it is $335.00 at Reds Headers :-) Dick
Strever is offline   Reply With Quote
Old 06-25-2010, 12:16 AM   #6
midgetracer
midgetracer's Avatar
Jim Gordon in LA(Rosemead ) repops the Winfield in Aluminum for around $300. They are not flycut, and I had to flycut mine for clearance. It runs real sweet and has lots of torque. The only Super Winfield I have ever seen was cast iron, and it sold for way over $300.
Midetracer
midgetracer is offline   Reply With Quote
Old 06-25-2010, 04:55 AM   #7
dean from bozeman
Here's the one at Red's Heads:
Head - Winfield for Model A & B
$335.00
· 1928 - 1934 Model A & B,
· Made from new 356-T6 Aluminum,
· 6:1 or 7:1 Compression
Is a Super Winfield and Winfield the same? Mine looks near identical except for the name. Unfortunately Red's didn't have a photo of the combustion side. I am unable to post a photo of mine. The circular space right above the piston is almost non-existent.
I am able to do some mechanical work but am not very experienced. Would a high compression head need to be installed any different than an original head? Different gasket? Sealant?
What are the driving advantages to using a Super Winfield? I realize that many A's have a sweet spot at 45mph. Would a high compression head raise that to 50 - 55? I ask because I have a chassis that will be used for a driver. I am 7 miles from town and the road is a 55mph one.
Thanks in advance for all replies.
Dean
Old 06-25-2010, 05:19 AM   #8
SUHRsc
SUHRsc's Avatar
The Super Winfield was a later produced aluminum version of the cast iron winfield. I believe that it wasn't Ed who made them. Ed Winfield was a believer in the use of cast iron heads to make the most power.
-WANTED-
Pre-War Speed Equipment
Davies or Morrison Intake Manifold
77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads
SUHRsc is offline   Reply With Quote
Old 06-25-2010, 08:39 AM   #9
John LaVoy
John LaVoy's Avatar
They are reproduced by an outfit in Rosemead, CA. I don't recall the name, I will have to dig into my files. I have visited them and have one of their heads that we have yet to install on anything.
John LaVoy is offline   Reply With Quote
Old 06-25-2010, 08:56 AM   #10
John LaVoy
John LaVoy's Avatar
The outfit is Specialty Ford Parts (626) 288-2121 Rosemead, CA
Old 04-06-2011, 08:02 PM   #11
foresthunter
foresthunter's Avatar
Please forgive the brainless question -
If I put on a Winfield head with 7:1 compression, do I need to do anything else to my engine?
Thanks in advance!
foresthunter is offline   Reply With Quote
Old 04-07-2011, 06:04 AM   #12
kelley's restoration
kelley's restoration's Avatar
Thanks in advance!
yes....
upgrade your ignition
try to not rev the engine real high
hold on to your hat lol
tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 04-07-2011, 10:38 AM   #13
Jim Brierley
The Super Winfield was made by the same Ed Winfield. Most of his originals were iron but a few were in aluminum, which is odd because Winfield once told us "if you want to make hot water, use aluminum, if you want power, iron is best". My recommendation for the average touring A would be the Winfield yellow head, 6:1, also available from Jim Gordon. (in aluminum)
Jim Brierley is offline   Reply With Quote
Old 04-07-2011, 11:03 AM   #14
Special Coupe Frank
Special Coupe Frank's Avatar
Thanks in advance!
Make sure your bottom-end is in good shape...
I wouldn't put one on a tired engine...
Special Coupe Frank is offline   Reply With Quote
Old 04-07-2011, 11:20 AM   #15
flyin-t
Jim,
you told me back in the 90's when I bought my Super Winfield aluminum head that they were built, the aluminum ones, by Bell auto parts. You pointed out how they tried to match the font of the word Winfield when they added the Super, but it's different...
One of us is getting old!
flyin-t is offline   Reply With Quote
Old 04-08-2011, 11:51 AM   #16
Jim Brierley
Not me! I won't be 74 until the 17th!!!
Old 04-08-2011, 12:33 PM   #17
foresthunter
Hey - thanks a ton for the comments & suggestions. I've got my 29 which is an aluminum (speedster) bodied A. I had a company in Spokane rebuild an engine and do a bit of balancing and reduction in flywheel weight. They've got a good reputation so the bottom-end should be good. I'm just looking for a good way to give it more umph while maintaining the original look/feel etc. Would the Winfield yellow head the best way to go about it?
TK - what would you do on the ignition?
Thanks again! I'm looking forward to running it around this summer. Last summer was great but since the tired engine was still in it, I had to stay pretty close to the house... and had a good trail of smoke to follow me by.
First on the cosmetic list is to get rid of those dang lights. I've got 29 light buckets but need to find the guts...
Learning how to make it fun.
