Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 05-22-2013, 03:29 PM   #1
My3window
My3window's Avatar
Default 1934 Oil Filler Tube
City: St. Helena
State: CA
Wanted: 1934 Oil filler tube. Unfortunately, someone shortened the one on my engine.
Please pm me with replies.
Thank you!
Tom
My3window is offline   Reply With Quote
Old 05-22-2013, 11:40 PM   #2
ken ct
Default Re: 1934 Oil Filler Tube
Yea they have the tall tube @ the top,real hard to find item. I have some of the lower ones but not correct for 34.The breather cap is also diff. ken ct.
ken ct is offline   Reply With Quote
Old 05-23-2013, 06:08 AM   #3
39wdy
Is this the filler tube that is approx. 8 and 3/4 inches long, bottom is about 1 and 3/8 inch in diameter, is tapered up about one inch from the bottom, is flared at the top, does not have any internal baffles, and only has one retaining indent also only about one inch from the top? If so I have one, no two of them. Perhaps these are the breather tube for the 8BA engines, I can't recall. What do you think Ken? P.S. still working on cleaning up carb parts and related parts for you. Best wishes, Toby
39wdy is offline   Reply With Quote
Old 05-23-2013, 07:40 AM   #4
1934
1934's Avatar
Tom, I have the oil filler tube for a '34, (it's the tall one). Unfortunately the aluminum base, (which bolts to the manifold), is broken. The tube itself is in good condition but not sure if it can be separated from the base. Maybe someone who knows could post with ideas how to do it.
What do you think, Kenct?
1934 is offline   Reply With Quote
Old 05-23-2013, 03:58 PM   #5
ken ct
Ive never had success pulling 1 of these tubes out of the die-cast base.Seeing the base is trash,try heating it with a torch and it may come out.Heat the die-cast part only. ken ct.
Old 05-25-2013, 02:32 PM   #6
33cabriolet
33cabriolet's Avatar
the original base was cast aluminum,can be welded but it is dirty from the oil
33cabriolet is offline   Reply With Quote
Old 05-26-2013, 12:07 PM   #7
My3window
My3window's Avatar
Thank to 1934 I now have one.
