Old 08-10-2023, 10:37 AM   #1
ole39
ole39's Avatar
Default sonic testing
looking for a flathead shop in west central illinois, or east central iowa that does sonic testing, my local shop doesn't do it.
ole39 is offline   Reply With Quote
Old 08-11-2023, 04:32 PM   #2
Pete
Pete's Avatar
Default Re: sonic testing
You can get a gauge and do it yourself if so inclined.
https://www.ebay.com/itm/31253585242...Bk9SR5D14ee8Yg
Old 08-11-2023, 05:37 PM   #3
ole39
ole39's Avatar
ok, thanks!
Old 08-11-2023, 06:45 PM   #4
tubman
tubman's Avatar
Thanks for posting that Pete. I had no idea such a thing existed.
Old 08-11-2023, 06:50 PM   #5
Pete
Pete's Avatar
You can get different size and configuration heads also so you can get in small ports for porting. You will almost never go through a port wall when using one of these.
Old 08-13-2023, 08:41 AM   #6
Bored&Stroked
Bored&Stroked's Avatar
Pete is correct . . . having the small probes that fit into the ports (while hogging them out) makes one a lot less stressed out! I've used them extensively for bores and for port work. I can sleep better at night as a result . . .
Make sure you always calibrate the unit on the block you're working with as a starting point. Also, they are not dead-nuts accurate . . . but close.
