Old 12-31-2011, 09:36 AM   #1
frederic
Default Anti chatter rods 1947 sedan
i climbed under my recently acquired 1947 sedan to do some electrical wiring up front. looking up I see two bolts near the front motor mounts I have not seen before on other similar cars. They are connected to two chatter rods running back to the correct mounting holes used. Is this a normal thing for the 42-48 Fords. I was always under the impression Chatter Rods ran rearward to the frame and not forward. In any event these do not help as the clutch still chatters like mad in forward or reverse. Most likely the motor mounts need changing but I believe this also could be caused by clutch disc being soaked in Automatic Trans fluid, which someone used in this transmission.
thanks for any help on this and Happy New Year to you all
Frederic
frederic is offline   Reply With Quote
Old 12-31-2011, 09:59 AM   #2
Mr 42
Mr 42's Avatar
Default Re: Anti chatter rods 1947 sedan
The 42-48 dont need the antichatter rods, its taken care of by the Gearbox mount.
So your rod's are probably added to fix a bad gearbox mount.
Mr 42 is offline   Reply With Quote
Old 12-31-2011, 10:52 AM   #3
41 Fords ohio
41 Fords ohio's Avatar
I agree with Mr 42 I've owned (7) 41s and a 46 ford and several have had chatter rods installed because of bad mounts. Ed
When will I be old enough to know better?
41 Fords ohio is offline   Reply With Quote
Old 12-31-2011, 02:08 PM   #4
Kube
Kube's Avatar
All 1941 Fords incorporated these anti-chatter rods (as they are commonly termed) as standard equipment. They did in fact run forward and bolted to the front cross member.
Old 12-31-2011, 02:36 PM   #5
JM 35 Sedan
JM 35 Sedan's Avatar
Listen up....Kube knows his stuff on these Fords
Kube, What is the length of the rods used in '41? and could they also be easily added to the '42 to '48 years? I am very familar with the '35-'40 rods but I have a set that are a bit longer than those and I think they may be the '41's. If I can find a picture of them I will post later. Thanks!!
John
Old 12-31-2011, 03:20 PM   #6
19Fordy
19Fordy's Avatar
FYI. There was also available an after market anti chatter device that bolts to the rear of the engine and hooks onto the "X" member. You could fabricate one without too much work. This is the one I have on my 40 in addition to the OEM rods - one of which you can see in the upper right hand corner. I welded little "ears" onto the 49-51 Merc bellhousing so they could used. Clutch is a 10 in.
Old 12-31-2011, 06:43 PM   #7
42guy
42guy's Avatar
You can use the 41 rods on 42-48. Finding the special spacers and washer/bolt combo are hard. I have them on my 42 but doubt how good they work.
The 41 units I beleive were put on some of the military models (42) as the GIs complained about chatter. I read this in an article in one of the Ford repair manuals.
I nbeleive the kit had a Canadian Ford part #.
42guy is offline   Reply With Quote
Old 12-31-2011, 10:19 PM   #8
1oldtimer
1oldtimer's Avatar
My '47 chatters something fierce, I grabbed some rods (I believe 41's) and was going to make them fit. Other then the clutch set-up being warped what else might cause this?. Will the trans mount really stop or at least lessen the chatter, as you can tell pulling the trans is not high on my fun meter. .
1oldtimer is offline   Reply With Quote
Old 12-31-2011, 11:12 PM   #9
41 Fords ohio
I was always told they were add ons, That's what I like about this hobby, I always learn something new every day. I just bought a 41 sedan in November that doesn't have them,and does't appear to need any. It also has a manifold heater that I've never seen on a 41 before. Thanks Ed
Old 01-01-2012, 01:12 AM   #10
Mr 42
Mr 42's Avatar
yes the gearbox mount on 42-48 takes care of the chatter,
if the mount is OK.
If you still have chatter then you having trouble with the clutch, and to replace it the easiest way is to remove the gearbox.
Old 01-02-2012, 12:42 AM   #11
columbiA
I had a 48 Merc coupe w-a very severe chatter.Turned out the rear splines on the DS & coupling were worn almost as thin as razor blades & DS roller brg surface was worn down almost 3/32".No wonder it had a1/2 turn play in the wheels! Ive taken many 37-48 RE,s apart & many of them had worn splines.
columbiA is offline   Reply With Quote
Old 01-02-2012, 04:17 AM   #12
1oldtimer
1oldtimer's Avatar
my trans needs to come out since 1st gear is missing a tooth, but I want to do it later when I have more room/time.....but that's another post.
Old 01-02-2012, 10:43 PM   #13
itstom
'41 anti-chatter rod is 21" from the "flange" to the center of the bolt, 21 7/8" over all. For what its worth, My car chattered like crazy with both rods in place and tight. Had to take off the one on the left side to fit my Fenton headers and the chatter really wasn't worse.
Put in a new clutch with an engine swap and the clutch has no chatter at all (still only one rod ). My guess is if your clutch is bad enough for you to write a post about it, that the rods probably aren't going to help.
itstom is offline   Reply With Quote
Old 01-02-2012, 11:17 PM   #14
BobM
Why do the early Fords have clutch"chatter?" My restored '36 had clutch chatter right from the git go; is it a design flaw?
BobM is offline   Reply With Quote
Old 01-03-2012, 12:07 AM   #15
1oldtimer
1oldtimer's Avatar
I just remembered I took pics of the frame I took the parts off of. I'm going to look at the trans mount, but ultimately the motor/trans has to come out to rebuild the trans, new clutch, new t/o shaft, new clutch arm and rebuild the pedal assy but I have to finish the panel truck first. I'll continue to collect nos parts until then. I just finished putting on the tube shock kit on the front and replacing the sway bar end links.
Old 01-03-2012, 02:44 PM   #16
Bruce Lancaster
The '42 conversion to rods is covered in the Canadian service bulletins...it was a wartime thing. Probably the desert war accelerated failure of the stock mount, which is LOTS of fun to change. The Canadians even supplied all the bits as a kit...
Pilots and several mercs also used the frontwards rods.
Old 01-04-2012, 04:40 AM   #17
barryfromvictoria
between 1961-1963 me and friends parted out about 10 `46-`48 fords and mercs most were original one owner 4 dr cars. most had anti chatter rods. we thought they weren`t necessary and we would usually chuck them if reinstalling a motor. so i always thought they were stock at least on canadian 46`-`48 fords and mercs.
barryfromvictoria is offline   Reply With Quote
Old 05-31-2012, 11:28 PM   #18
tandj1941
itstom- I too took my left chatter rod off my 1941 to fit Fentons and others on this site acted like I was crazy. They said they wouldn't even run the car like that, but I have had no problems. Should I worry about taking the car on loger trips? I was going to fab one like 19fordy suggested.
tandj1941 is offline   Reply With Quote
Old 06-01-2012, 03:28 AM   #19
Ian NZ
Ian NZ's Avatar
All the Canadian 1946 - 1948 Fords and Mercurys that were imported into
New Zealand had Anti Chatter rods.
Ian NZ is offline   Reply With Quote
Old 06-01-2012, 04:19 AM   #20
Mart
Mart's Avatar
Longer trips should not be an issue. It's manouevreing at low speed when you tend to have a problem.
IMO
Mart.
