02-04-2012, 09:21 PM | #1 |
tightening cam gear
Is there any other way to hold the model A cam from turning when torquing the cam gear besides the gear itself against the crank gear?
02-04-2012, 09:56 PM | #2 |
Re: tightening cam gear
Wad up a little soft rag and poke it in where the teeth meet. Bill W's Ghost
02-04-2012, 10:55 PM | #3 |
I like to leave the side cover off and use a clamp on the cam gear.
02-05-2012, 12:16 AM | #4 |
I did mine before installing the cam,used soft jaws in my vice.
Lawrie |
02-05-2012, 04:13 AM | #5 |
This way has worked for me as well.
02-05-2012, 09:59 AM | #6 |
V4f |
02-05-2012, 10:05 AM | #7 |
Ditto on what Bill W's Ghost says. I save the wood like Steve Norcal says to use for on my Harley's primary chain.
AMF/Bob-A |
02-05-2012, 01:16 PM | #8 |
Wad up a soft rag and put it in the teeth.....will this damage an aluminum cam gear ?
02-05-2012, 01:36 PM | #9 |
If you are doing it in a vise, soft jaws work great along with a strap wrench as a back-up to keep it from turning.
02-05-2012, 01:54 PM | #10 |
If it is an aluminum or bronze cam gear, I do it the way Bills ghost does. If it is a fiber gear, I do it George Millers way, so as not to fracture or break the weak gear teeth.
02-05-2012, 02:20 PM | #11 | |
Dandy idea! I never thought of that one. Chief always said, "There's more than one way to skin a cat!" He often also said, "The easiest way is the best way if it does the job PROPERLY!" Don't ever use an impact wrench on a cam gear nut, and don't ask me why I say that +*%$&#Bill W's Ghost
02-05-2012, 02:22 PM | #12 |
I use an impact all the time, but only with the cam in a bench vise.
02-06-2012, 01:14 AM | #13 |
There is more than 1 way to skin a cat, but, no matter how you do it, you are not going to get the cat to like it!
02-09-2012, 01:29 AM | #14 |
The rag method above is a realy bad idea regardless of the cam gear material.
Use the clamp method with a flat bar of steel or aluminum clamped on the rim of the gear. Dan |
