09-21-2016, 07:22 AM | #1 |
Melling M-15 Flathead Ford, High Volume Oil Pump
City:
Pasco
State:
WA
Price:
125.00
Melling M-15 Flathead Ford, High Volume Oil Pump with the Speedway Motors pick-up tube.
The oil pump is used, approximately 5,000 miles and works great. It pumps 25% more volume than the standard Ford flathead motor. The high volume oil pump may require oil pan modifications. The high volume oil pump is approx. 1-1/4" deeper than an OEM '49-'53 oil pump. The bottom of the pan will most likely require modification to accept this additional depth. If this pump is to be used '48-older block, you will also need the Speedway Motors pick-up tube 910-16259. Pump measures 5-1/2" from mount surface to bottom of the pump. I removed the oil pump from a tired Ford Flathead, am moving and have no use for the pump at this time. Asking $125.00. If interested please shoot me a PM or give me a phone call @5095547499 instead of a text message. I am not real quick to reply text messages. |
10-03-2016, 06:59 AM | #2 |
Re: Melling M-15 Flathead Ford, High Volume Oil Pump
Price change, $100 obo.
10-15-2016, 06:43 AM | #3 |
