Old 01-21-2014, 02:15 PM   #1
Ole Lou
Default battery disconnect switch on 32
Where do most people mount and install a battery disconnect switch on a model B? Car not driven a lot and don't want to take out floor board every time to disconnect battery.
Ole Lou is offline   Reply With Quote
Old 01-21-2014, 02:42 PM   #2
sonny
sonny's Avatar
Default Re: battery disconnect switch on 32
I mounted mine in the floorboard about 2 inches in front of the seat. It's close to everything and you don't see it with the mat over it.
sonny is offline   Reply With Quote
Old 01-21-2014, 02:59 PM   #3
32phil
Mine is on the Battery. Just lift up the mat and metal cover and there it is.
Early Ford Lock & Key Service
https://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 01-21-2014, 04:57 PM   #4
Drbrown
Drbrown's Avatar
Believe it should be installed on the ground side of the battery.
Drbrown is offline   Reply With Quote
Old 01-21-2014, 05:30 PM   #5
G.M.
On the front of the seat riser on some models is a good place. I don't think it makes a difference on which side of the battery the disconnect is on. Get a good disconnect, the small green handled ones do not make good contact and I have had 3 or 4 go bad. They are made of aluminum that is anodized a yellow color to look like brass. A heavy duty panel mounted one can also be made mount on the battery. [email protected] made the heavy duty battery mounted type at one time. Contact Bob Shewman to see if he still supplies them. G.M.
www.fordcollector.com
Old 01-21-2014, 11:32 PM   #6
fordor41
fordor41's Avatar
Where ever you put it make it EASY to get to. 30 sec can be a lifetime if you have an electrical problem and need to get to the switch in a hurry. Mine is were I can get to it even going down the road.
fordor41 is offline   Reply With Quote
Old 01-22-2014, 12:14 PM   #7
keith oh
keith oh's Avatar
True, true fordor 41, I have experianced solinoid sticking and it is not fun trying to get the battery wire nut loose while the started is running wild, with your wrench shorting against everything near. Usually a smart smack on the solinoid opens it but not always.
keith oh is offline   Reply With Quote
Old 01-22-2014, 12:21 PM   #8
tiger.1000
Lou, many years ago I committed a cardinal sin by cutting a hole in the floorboard just big enough to get the battery in and out and fit a battery isolator. PM me if you need a photo.
tiger.1000 is offline   Reply With Quote
Old 01-22-2014, 06:56 PM   #9
woodiewagon46
Good suggestions from all. I mounted mine in my trunk. My battery is located in my trunk so it made it easy. It also gives me a little more security by not having it in view. I can open the trunk in a few seconds.
woodiewagon46 is offline   Reply With Quote
