Old 06-28-2016, 06:35 AM   #1
white64
white64's Avatar
Default Installing 39 coupe windows
It looks like you have to unbolt the regulators, hook the new glass onto them and install as a unit? OR... pivot the regulators on one of the six bolts (which one?), Suggestions?!
...the regulators on 39s are big and have a removable center pivot point.
Bought the glass from Bob's Classic Glass (should have them this week), he called me personally and gave me a few pointers about adjusting the '39 glass. Even suggested adding a 3/16 rod to ride vertically in the channel in front so the window wouldn't twist and jamb in the felt channels, possibly damaging them, I'm going to take that advice.
white64 is offline   Reply With Quote
Old 06-28-2016, 09:55 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Installing 39 coupe windows
I don't understand the "rod" theory. 39 Ford coupe's front windows move back before going down in the channel
Jim
Kahuna is offline   Reply With Quote
Old 06-28-2016, 10:24 PM   #3
Ken/Alabama
Ken/Alabama's Avatar
Put the glass in the door with lower Chanel installed on the glass then put the regulator in the door while holding up the glass and insert the regulator arms in the Chanel then slide the whole thing up to put the screws in.
Old 06-29-2016, 05:16 AM   #4
white64
white64's Avatar
Ken: Well that makes perfect sense! Thanks!
Jim: I will examine the rod "theory" a little closer before doing it... And thanks for the heads up!
Old 06-29-2016, 11:59 AM   #5
RKS.PA
RKS.PA's Avatar
When you put your new glass in the regulator slot, don't skimp on the bedding strip. It makes a world of difference when you get a nice snug fit.....don't ask me how I know!!
Dick.
RKS.PA is offline   Reply With Quote
Old 07-01-2016, 06:42 PM   #6
white64
white64's Avatar
Here's the rest of the story! I'm putting 39 style windows in 40 doors. I wasn't aware that 39 windows moved back when you rolled them down, I can adjust the '40 doors to make that work... However, when the glass was cut it seems they thought I might be using the '40 regulators. since the glass I got doesn't seem to fit the '39 channels. it's almost link the '39 glass should be notched on each end to fit the bottom channel... is that correct?
Old 07-06-2016, 06:30 PM   #7
fishnjim
I am also having a very difficult time getting my windows to wind up and down without forcing them a bit. Without the garnish moldings on, I can get them to close with a slight tweak/push/pull on the top of the window.....but have no chance once the garnish molding is on. I am wondering what some others have found with these? We had no problem with doing our square glass on a 30 pick up or on dads 40 coupe. But this 39 with the window moving forward right when it goes to the top has given me grief.
fishnjim is offline   Reply With Quote
