08-29-2016, 08:51 PM | #1 |
How many of these were made?
I spoke to a gentleman today about a
Ford truck he has that he wants to sell me. Can anyone tell me how many of these tandems were made? I wanted 1 of these trucks for along time to make a rollback out of. Is this military? Thank u for any help or any pictures of the same truck that maybe some here might own. He couldn't tell me if it was air brakes? Would someone know possibly the weight of this monster? Many thanks |
08-29-2016, 09:01 PM | #2 |
Re: How many of these were made?
Nice photo. Do you have one of the truck also?
Matt 24:36-41 |
08-29-2016, 09:09 PM | #3 |
if its military, they all came with a data plate, usually on the glove box door or on the dash. data plate will give weight, load capacity, government ID #(g number=for parts referance) and related manuals. you dont give much of a picture to guess off of. most tandems of that size in that era will not have drive to both axles,but again hard to say from the photo. crawl under it, drive shaft to both axles? air brake lines (hoses and air chambers), or regular hydraulic lines?
08-29-2016, 09:10 PM | #4 |
Air brakes i doubt. The ones i have seen were aftermarket conversions. The last one i looked at had a tag from a company called Truckstell . Not 100% if the spelling is correct. For the suspension between the drive axle and the ad on tag axle there was a large roller chain and a sprocket fixed to the frame rail. The ends of the leafs were the shackle would have been is were the roller chain was fix. There were a few different types.
We had a 54 ford F600 that started as a single axle and was converted to a very odd full screw tandem with a 2 speed power divider. We also had a 55 ford T750 which was a factory tandem with Hendrickson suspension air brakes. 5 and 4 transmission with power steering. |
08-29-2016, 09:32 PM | #5 |
Here's a thread with good info. For one thing, no factory tandems until '54.
http://www.ford-trucks.com/forums/14...-toy-home.html
'52 F-1, EAB flathead |
08-30-2016, 11:55 AM | #6 |
08-30-2016, 03:11 PM | #7 |
It could be a Thornton drive rear end?
08-30-2016, 06:18 PM | #8 |
Agree, that or Warford Sextette, provided it is a twin screw. Could be a tag axle, either commercially made or homegrown. As to the comment about military Fords having separate round gauges, that only came into play in 1942 when Uncle Sam wanted to standardize things. Prior to that, military vehicles came with the manufacturers own dash.
I dig coal, which provides motivation for EVs. |
08-30-2016, 06:25 PM | #9 |
The G8T was first manufactured in 1942 model year. Prior vehicles were different models for lend lease so I agree they didn't change them much.
