02-05-2012, 11:39 PM | #1 |
Masking for second color on body and doors
Any tips for the type and size of masking tape that I should use for the second color on the doors and body on the 29 Tudor that I am getting ready to start painting (when the weather warms up--Ha)??? I'm thinking a narrow tape for those tight bents around the windows and doors. Eastwood has some high temp tape for powder coating that they say is good for sharp edge masking http://www.eastwood.com/high-temp-bl...king-tape.html and then there is this tape--1/16" for tight curves--- http://www.eastwood.com/crepe-tape-1...x-55yards.html It has been a long time since I did any paint work like this and I know there are a lot of new products out there but I am not familiar with them.
02-05-2012, 11:54 PM | #2 |
Re: Masking for second color on body and doors
Go with you used to use!! You will be much more comfortable!! Post a picture and explain how you want the colors and I'll explain how to mask it up!! Or pm me you email and we can correspond directly.
02-06-2012, 10:03 AM | #3 |
The blue plastic tape works very well for two tone painting. I use 3M tape, but this looks to be similar. I use 1/8",1/4",& 1/2" when two toning, on long runs the 1/2" works very well in getting a very straight line and the other sizes on the curves and corners.
It does leave a very crisp line without any bleed back. It is the best you will do for this purpose.
The only thing that can beat an attempt----is a failure!!!! |
02-06-2012, 11:28 AM | #4 |
I personally prefer a 3M 1/8th paper Fine-line tape rather than the plastic as it does not stretch like the plastic tape does. The Eastwood tape is likely fiberglass tape which if it is like our powdercoating tape, it is a thicker Mil which would make corners more difficult.
02-06-2012, 08:47 PM | #5 |
I've used Scotch® Tape 4737T with Dupont Imron® on two tone fiberglass truck clips. It is just a tiny bit stretchy so it follows fairly tight contours and turns without too much trouble. The "T" at the end of the number is the translucent version. I like the "T" because you can see any bubbles, hairs, dust specks or other lack of adhesion at the edge which would cause annoying bleed. You can visually confirm the edge will be clean.
Here's a link to the 3M product sheet for 4737S & T |
02-06-2012, 10:17 PM | #6 | |
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
02-08-2012, 11:36 AM | #7 | |
Here is a "before" picture of the Tudor --the new paint colors will be Bonnie Gray and Chelsea Blue (I have no idea what the "before" colors were!!!) I am assuming that the paint scheme is correct even though the colors are not! |
02-08-2012, 08:59 PM | #8 | |
Brent--You wouldn't happened to have a part number for that tape? |
02-08-2012, 09:33 PM | #9 |
any real parts store sells real 3m pin stripe tape .any size from about 1/6 up to 1/4 will not only go around corners but it also seals better than any other tape to prevent paint bleeding under the tape. do the edge with this, then tape up to that with regular masking tape. if using news paper for cover, remember to tape the seams shut between the sheets and look for small perforated holes in the paper that i usually only find after paint is sprayed thru! also, if you pull the pin stripe tape while its still wet it will "flow" out a little and not leave such a sharp edge
02-08-2012, 09:48 PM | #10 |
Fred93, that is a pretty combination of colors on that Tudor!!
02-08-2012, 09:58 PM | #11 |
