Old 01-24-2012, 01:59 AM   #1
badbones
Default Rear drum bearing and seal
I just installed one of the seals in the new drum. I repacked the bearing and dropped it in. I then installed the seal. I think I may have gone a little far with the seal as its about 1/8" below the snap ring.
So my question is should the entire bearing rotate inside or is the seal is against it will it prevent it from rotating. The internal rollers seem to roll fine but its still sticky with the new grease. I cant compare to the other side as I have replaced that drum too. I have not installed that seal as of yet.
Also which way does the key face. I forgot to mark them when I took them off.
badbones is offline   Reply With Quote
Old 01-24-2012, 05:51 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Rear drum bearing and seal
Can you move the bearing in and out at all? If not you'll have to pull the seal back some. It's been a long time since I messed with the rear drums, but as I recall the taper on the key faced in, to fit the curve at the end of the keyway cut.
Old 01-24-2012, 12:39 PM   #3
badbones
The bearing does not move front to back. Is there an easy way to move the seal back with out destroying it? It's a pretty snug seal. Was thinking of the one foot drop method but not sure if that wil or damage anything else n the process
Old 01-24-2012, 01:18 PM   #4
Tom Wesenberg
I don't know of any good way to pull the seal back without destroying it. Since the seal is holding the bearing tight, I doubt dropping it a foot would loosen it. In fact most of the rear wheel seals I've installed had to be sanded before they would even begin to go in without kinking.
Old 01-24-2012, 02:37 PM   #5
Bob C
As Steve from Bert's said just drop the drum on a concrete floor and the bearing will
push the seal out. If you leave the snap ring in it should just push the seal up to
the snap ring.
Bob
Old 01-24-2012, 02:42 PM   #6
mass A man
mass A man's Avatar
badbones, I made this mistake ONCE. I ended up destroying the seal to get it out. I prep the new seal for a proper, yet tight fit, I use an old worn out rear bearing for my seal driver, tapping it down with a piece of hardwood and hammer. When I get even NEAR the snap ring groove, I check and double check to drive new seal far enough down past groove just to get the snap ring in. Thinking about the problem you're having, Maybe a "slide-type" dent puller with some kind of custom "end" on it would pull up your seal a bit. I guess maybe I'm only dreaming. I wouldn't reccomend any dropping of the drum, or even putting a torch to it. You don't want to hurt the integrity of the drum for a $4.00 part.
mass A man is offline   Reply With Quote
Old 01-24-2012, 03:36 PM   #7
Pilotdave
Pilotdave's Avatar
I'm with those who are suggesting replacing that seal with a new one. I just went through the seal removal game - until someone invents a seal pulling tool I don't see any safe way to get the seal out without destroying it.
I'm close to reinstalling the bearings and seals on my car - while it's too bad that you are having this problem, thank you for posting about it as doing so should save me from repeating your mistake!
Pilotdave is offline   Reply With Quote
Old 01-24-2012, 04:32 PM   #8
Jim Parker Toronto
Jim Parker Toronto's Avatar
I don't recommend this fix, but go ahead. What have you got to loose... besides a $100 drum and $75 labor charge to mount the new drum and turn it . Let us know how it works out for you.... If you do drop it on floor, be sure to check for cracks and out of round before you install it!
Jim Parker Toronto is offline   Reply With Quote
Old 01-24-2012, 04:52 PM   #9
silvertop
silvertop's Avatar
I am viewing a cut away view of the bearing in the hub. It is showing a space between the snap ring and the seal of what looks to be about 1/8". The bearings are in a cage and do not rotate against the seal or the hub. The view shows the seal limiting the lateral movement of the bearing.
I have installed the seals this way in the past and have had no problems.
The only thing that can beat an attempt----is a failure!!!!
silvertop is offline   Reply With Quote
Old 01-24-2012, 05:41 PM   #10
badbones
Silver top
I did order a new seal and plan to install the other one tonight in the ther drum. The rollers in the bearing do roll, but the cage they are in dont. The red bearing grease I used is sticky and wonder if that's preventing movement if the age should rotate that hold the rollers. There is no movement front to back of the age. I just don't want to remove and replace the seal if I don't have to. When I removed the seal I found that a large flat nail puller worked great. It gave me leverage and was able to pop the old seal out in abut a minute or so.
Old 01-24-2012, 05:54 PM   #11
silvertop
silvertop's Avatar
The cage must not rotate, if it did, it would wear the hub and the seal. I have found wear like this on bearings that have failed, locking up in the cage and rotating the complete assembly. That gets ugly!
Old 01-24-2012, 06:03 PM   #12
Pilotdave
Pilotdave's Avatar
Thinking more about this....why does the bearing cage need to be free to move? If the rollers are free to move, then they will spin as the hub rotates on the axle. And, as silvertop suggests, a rotating cage would wear either the seal or the hub. If so, then why would there be a need to move the seal back out to the snap ring? Just questions from a relative newbie!
Old 01-24-2012, 06:15 PM   #13
silvertop
silvertop's Avatar
The illustration that I refered to is on page 23 of a publication copyright, 1928 by The Norman W. Henley Publishing Co. and has been reprinted by Floyd Clymer. (Clymer Repair Manuals)
Pilotdave, you have it right, the lateral movement needs to be controled, and the illustration confirms that.
Old 01-24-2012, 06:23 PM   #14
Tom Wesenberg
If the cage can't rotate, neither can the rollers.
Old 01-24-2012, 07:08 PM   #15
d.j. moordigian
d.j. moordigian's Avatar
Tom,
I would like to see the bearing "float" say .010". But even if the cage is tight,
the rollers are still going to rotate. Are WE missing something?
No shot, just thinking. Dudley
d.j. moordigian is offline   Reply With Quote
Old 01-24-2012, 07:20 PM   #16
mass A man
mass A man's Avatar
Why, then is the darn snap ring groove so far away? And like Tom said, the rollers won't move either. I know some rear bearings have the roller "pins" that ride in the holes of the cage, whereas I think the re-pro's are solid cages.
Old 01-24-2012, 07:44 PM   #17
Pilotdave
Pilotdave's Avatar
If the the cage has to rotate in order for the rollers to rotate, wouldn't that wear out the end plate (or some other vital part of the assembly) of the cage in short order?
Old 01-24-2012, 08:04 PM   #18
Tom Wesenberg
No, because there is really no side pressure on the rollers or cage. If the cage is stout enough you might try to loosen it by poking a screwdriver through from the other side and tap on the inner edge of the cage by the seal. My guess is the cage might bend before the seal moves though.
