Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 12-20-2014, 07:44 PM   #1
SJ13
SJ13's Avatar
Default hood latch cable
need advice on how to free up a frozen hood latch cable, I removed it from the car started squirting oil down the inside of the cable applie a little heat and put slight pressure on it, slight movement @ first but nothing since any other suggestions , Thanks in advance for your suggestions
SJ13 is offline   Reply With Quote
Old 12-21-2014, 11:35 AM   #2
redmodelt
redmodelt's Avatar
Default Re: hood latch cable
You need to soak it good with a good penetrating oil like Kroll's or such. WD40 is NOT a penetrating oil. Then keep working it till it's freed up.
This is the section for questions to the editors about the site not general car questions.
If this is a Ford question ask in the appropriate section.
Old 12-22-2014, 02:21 PM   #3
SJ13
SJ13's Avatar
ok thanks for the cable advice ... will post appropriately next time
