04-16-2012, 01:19 PM | #1 |
Drop Staight Axle vs IFS
I realize the forum is stock related, but for ride, steering, is there really a difference? Please share the pro's -n- con's. Say M II vs drop straight axle, or is it really only a self-preference. Thanks - lo
" You haven't lived until you've almost died.For those who have fought for it, life has a meaning the protected will never know. " |
04-16-2012, 01:36 PM | #2 |
Re: Drop Staight Axle vs IFS
It depends on what your gonna do w/it. If you want a classic car - use the dropped axle and flathead . It will drive ok and you will have more fun in my thinking . If you want it to drive like a modern car w/sbc - a/c - auto then use a m2 . If its a 35 or newer w/fenders you won't see it anyway . You car you choice . I'm building a '32 5/w with a dropped axle , flathead , s10 trans , and converted banjo rear and no a/c . I have both kinds and I enjoy the flathead cars more than sbc ones .
04-16-2012, 01:45 PM | #3 |
Sorry Jerry, I'm building a '37 c dan. Yes on it being a driver, and yes to a/c, sbf
04-16-2012, 02:57 PM | #4 |
a straight axle front end can be made to ride pretty nice, but if its true comfort and control on rough roads you cant beat the independent front suspension, cost wise about $1100 complete, if you want nostalgia go straight front axle, for a more presice handling and comfort use the independent front
04-16-2012, 03:14 PM | #5 |
Thanks, I'm on the fence. There seems to be more room with straight axle, under the hood. Also I really don't want to totally rebuild the hole frame. I' m not a full fledged car builder. Remove replace, rebuild etc. Is more my speed, I tend to only be able to depend on my skills, and keep others out of my pocket.
04-16-2012, 03:25 PM | #6 |
04-16-2012, 04:25 PM | #7 |
When it comes to quality of a light car like a roadster, there's not much you can do to the quality of ride. You can use IFS, coil overs, air bags. It all boils down to sprung to un-sprung weight. The spicer 35 is about the lightest modern rear axle. but a 100 lbs of junk in the trunk will help too.
04-16-2012, 04:43 PM | #8 |
Ol' Ron I'm sure you mean well.. but what? ('37 Ford)
04-16-2012, 04:47 PM | #9 |
Street rod uses independent. Hot Rod uses straight axle. It all depends on what kind of ride you are building.
04-16-2012, 05:05 PM | #10 |
Well there is a ' 39 sedan f/s and my eyes where opened to a different way of thinking. I've had a one track mind to this point. And started me thinking a different way. Full fendered '30s '40s car = IFS I'm sorry I didn't want to cause any drama on this informative site, so much to learn. I'm leaning towards the drop straight axle, and was only looking for others thoughts on this topic. I'm not as informed as others.
" You haven't lived until you've almost died.For those who have fought for it, life has a meaning the protected will never know. " Last edited by lo c dan; 04-16-2012 at 05:12 PM. |
04-16-2012, 05:16 PM | #11 |
Dropped axle will keep your Ford honest!
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
04-16-2012, 05:24 PM | #12 |
I've got a straight axle under my 39. I think it handles very well. Has many highway miles and my wife even likes riding in it.
04-16-2012, 06:54 PM | #13 |
The IFS works great in the heavery cars, but keep the rear axle light.
04-16-2012, 08:16 PM | #14 |
I have one of each and I wouldn't think of starting on a 500 mile-a-day trip in the straight axle car. The steering is what I think it should be, no wandering or shimmy, but the steering is precise and the ride is much more comfortable in the M II and parallel leaf rear springs and you can make much better time. My opinion is that the straight axle is fine for local or occasional drives but gets tiresome on longer stints.
It would be great if you had access to one of each to form your own opinion. |
04-16-2012, 08:21 PM | #15 |
A luxury I don't have...access to either one.
04-16-2012, 08:56 PM | #16 |
I have a 4'' dropped axle,reverse eye spring and sway bar on my 37' and I drive it every day to work. It handles like a dream! it's much simpler than a Mustang II and you don't have to cut it up!
04-16-2012, 09:37 PM | #17 |
If I wanted to drive a Mustang two, I would buy a Mustang Two. I have seen a lot of independent front suspensions and they just do not make an old Ford look right. I would not buy a car that has been converted and I would not install one.
My neighbor has a 34 Ford with a Corvair front suspension and he wants to change it back to a straight axle. This was a trendy conversion in the seventies and the Mustang Two is trendy now. Trendy things just do not last and devalue the car. Another friend has a Forty Ford with a Nova front end welded to the 40 Ford frame. He can not sell the car and he now hates the car and wishes he would have never made this dumb mistake. This was another trendy conversion. The straight axle will never go out of style.
IF IT CAN NOT BE FIXED WITH BLASTING WIRE, JB WELD OR DUCT TAPE ---IT CAN NOT BE FIXED Do not get me started on the stupidity of ethanol. I think one of the monitors is from Iowa and he will delete the thread. Last edited by sturgis 39; 04-16-2012 at 09:43 PM. |
04-16-2012, 09:51 PM | #18 |
I have had both and I will never go the mus II again. I saw no advantage to the mus. over the several solid Axel fords I have driven.
04-16-2012, 10:26 PM | #19 |
I have had both. I loved the way my 40 sedan drove with dropped Super Bell and Posies spring . Drove it cross country several times. However on my newest 40 I used a CE MII setup with QA1 coilovers and REALLY like the ride and drive. If you want your 37 to be a "lo c dan" either setup will take a considerable amount of work and cost close to the same when done right.
04-17-2012, 08:33 AM | #20 |
I will add a little more----When I rebuilt my 40 a few years ago, It was a total "frame off". My original frame was straight, level and true. I couldn't bear the thought to cut it up. I went with a narrowed, dropped front axle, Posey spring, four bar, billet hubs and rotors, custom sway bar and custom shocks. The ride is quite good and it handles "like a bear". Honestly, a well engineered IFS probably rides better---but I preferred to keep the basic original design.
The setup I used is expensive----so you are not saving any money with a dropped axle, etc. |
