10-26-2015, 08:45 PM | #1 |
Correct Coil Resistance
I have been chasing an intermittent stumbling of my engine when under load and have replaced or checked out all ignition components and am now to the coil. I got this diagram from some authoritative source and have always suggested it to others. Primary coil is in the range of the diagram. But when I just checked the resistance of my secondary coil in my stock 47 Ford coil that Skip Haney rebuilt I only get 6,130 ohms, not the 10-11,000 ohms per the diagram. Is that low enough to affect the spark or not? Is the coil bad and needs replaced or just marginal?
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
10-26-2015, 09:26 PM | #2 |
Re: Correct Coil Resistance
Call Skip.
10-26-2015, 09:59 PM | #3 |
You got it. Get the correct coil rebuilt and forget these abortions. G.M.
www.fordcollector.com |
10-26-2015, 11:03 PM | #4 |
Henry, I chased a miss or skip as you call it on the 33 for ages,turned out to be two loose valve guides and those two let oil into the cyl and fouled the plugs ,ran like a train while burning along at 50mph but slow and speed up and the miss was there.
Lawrie |
10-26-2015, 11:18 PM | #5 |
So far I've replaced all of the spark plugs, the points, condenser, rotor, and coil resistor. All I can think of that's left is the coil so I'll call Skip tomorrow and see what he thinks. I'll also PM Bubbas Ignition since he hasn't commented to see what he thinks of the low resistance secondary coil.
10-27-2015, 06:13 AM | #6 |
10-27-2015, 09:00 AM | #7 | |
10-27-2015, 09:08 AM | #8 |
10-27-2015, 11:22 AM | #9 |
Henry, Is this the same problem that you said leaving the hood open a bit while moving helped some?
10-27-2015, 11:54 AM | #10 | |
Right now I'm driving with my timing light taped to the cowl so I can see its flashes through the windshield while I drive. The pickup is on the high tension wire coming out of the coil. I mainly did this to confirm that it is a spark problem, not a fuel problem. Sure enough, when the engine stumbles so does the light flashes.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 10-27-2015 at 12:03 PM. |
10-27-2015, 11:56 AM | #11 | |
To be able to calculate output voltage you need the turns ration of the coil. |
10-27-2015, 12:32 PM | #12 |
Sounds like a loose wire or connection unless it is heat related. Or a vacuum / carb issue on the advance. Are you running the original vacuum only advance distributor?
10-27-2015, 12:36 PM | #13 | |
It certainly acts like a loose wire so I bypassed all wiring from the battery to the coil with a jumper from the battery to the coil. Didn't help.
10-27-2015, 02:02 PM | #14 |
Check the spring loaded contact in the distributor if its a crab ,Ted
10-27-2015, 02:11 PM | #15 |
10-27-2015, 02:19 PM | #16 | ||
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 10-27-2015 at 06:53 PM. |
10-27-2015, 02:25 PM | #17 |
I think I figured out what you're talking about - the terminal that the wire from the coil connects to that has a spring loaded post that pushes against the points plate? If so, I can take that out and check it. I just removed that plate to replace my points and twisted the plate against that post to position it so hopefully it's OK. Distributor was built by Bubba a year or two ago.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 02-28-2016 at 11:46 PM. |
10-27-2015, 03:07 PM | #18 |
Yes, it is the post for the coil wire.
The only reason I found the problem is that it finally quit totally and I found it was open circuit between the coil wire screw and the inside brass plate. Unscrew the post and then polish the end of the spring loaded pin with emery cloth. You can probably clean up the brass plate with emery cloth too without taking the distributor apart again. My distributor was serviced by Bubba too and he cleans and checks that connection. But for some reason it still failed. See more (and Jim L.'s response) at: https://www.fordbarn.com/forum/showth...52#post1152852 |
10-27-2015, 03:11 PM | #19 |
Looking at your distributor photo again, it looks like that pin is way off to one side and hardly making contact. Perhaps the photo is of a different distributor?
10-27-2015, 03:16 PM | #20 |
That is an old photo of my original distributor that was worn out, not the one Jim built for me. It isn't even all together. You won't find the retaining ring around the points plate. That was the one Jim got in exchange for the one he sent me.
