07-28-2015, 04:16 PM | #1 |
1952 ford car flathead generator to voltage reg wiring
can anyone please tell me wiring for gen to vol reg i have 2 52s one rat other decent stock... i found one for a 64 1/2 mustang i think that is clear but dont know if thats correct for a 52 any pictures of wiring would sure help thanks dennis... one works correct but doesnt seem wired same as the big plastic wire dia i have but puts out about 8 volts at 1500 rpms... thanks dennis
07-28-2015, 04:45 PM | #2 |
Re: 1952 ford car flathead generator to voltage reg wiring
I am totally confused on what you are asking! Are you just wanting to know the normal generator to voltage regulator wiring? Why not look at a wiring diagram, easy to find on the internet. There are three wires that connect to the voltage regulator. The power wire back to your circuit breaker panel. It connects to BAT on the regulator and is a heavier gauge wire. Then there is the field wire from the generator that connects to FLD on the regulator and armature wire that connects to ARM on the regulator. There should also be a ground wire from the generator to the case/mounting screw on the regulator.
Note: on the diagram they are marked B, F & A |
07-28-2015, 08:43 PM | #3 |
what i wanted to know was correct color wires from voltage reg to generator,, i had put a new regulater on this morning then found the wire to g and f were reversed at the genso now of course still no voltage coming out sure hope something didnt burn out in gen....guess im just getting to old to work on these...i didnt reverse them thats the way they were when a friend helped me wire it thanks again dennis
07-28-2015, 09:11 PM | #4 |
LOL, OK, now I have some idea where your going. Ford was fairly consistent with the wiring colors.
Ground from the side of the gen to the reg mounting bolts/screws Black/Red Field from the side of the gen to the reg FLD or F terminal Black/White Armature from the rear of the gen to the reg ARM or A terminal Yellow/Black Power out from the reg BAT or B terminal Solid Yellow Does that help any? |
07-28-2015, 09:24 PM | #5 |
