02-28-2014, 01:13 PM | #1 |
Do I have a Business Coup or 5 Window
Here are some pictures of a 40 Ford Coup I just bought and am trying to figure out if it is an original Business Coup or 5 Window Coup. Apparently the floors are different in the back seat area. I want to get some replacement sheet metal floor panels for it and I've been told that the floors are different between the two models.
I'll try to load some pictures now. Steve |
02-28-2014, 02:31 PM | #2 |
Re: Do I have a Business Coup or 5 Window
Below are photos of my 1940 DeLuxe 5 Window Coupe, Model 01A-77b that came with the package tray. The business coupe (Model 01A-67B) had the small opera seats. Do you see any holes or supports where the small rear fold down seats might have attached?
Also. it looks like a large rectangular patch panel has been welded into your floor and the 3 angular braces have been extended and repositioned for some reason. I venture to say you have a 5 window coupe with an altered floor and braces. Last edited by 19Fordy; 02-28-2014 at 03:02 PM. |
02-28-2014, 02:40 PM | #3 |
I agree with 19fordy. The step-down on my business coupe is to the rear of the vertical post for the spare tire mount. The spare tire is actually forward of the step-down, and the floor is flat from there on forward. Notice the difference in the angled braces that attach to the fender wells.
02-28-2014, 02:57 PM | #4 | |
02-28-2014, 03:16 PM | #5 |
Did the business coupes have jump seats? I always thought there was just a tray behind the seat on business coupes.
Son, you will never blow an engine up in high gear. |
02-28-2014, 03:21 PM | #6 |
02-28-2014, 05:54 PM | #7 |
19Forty and V8 Bob.....thanks so much for your help on this. I understand and agree that my car must be the 5 window coupe model. I do have the ledge L shelve for the package trey. It is hard to see, but it's there. I also have the old package trey wooden frame. All I have is the spring frame for the front seat, so I'll be looking to find that whole front seat assymbly with the hinged back rest as well.
My first task is to find a supplier that makes the floor pans for this rear trunk area and into the back seat. Any help on suppliers on that would be appreciated. Your right about the "patch job" that somebody before me did on that rear seat area, it's really ratty. Also, I don't know why those vertical supports are located the way they are. Your picture of your car seems to show these mounted much higher on the wheel wells, and my spare tire support looks like it is wrong too. It should run further into the trunk area. These vertical supports are really in poor shape.....Does anybody reproduce these support brackets??? 19Forty....can you please shoot a picture of your back seat area from the inside of the car, just to show me what it should look like from that angle? Is that area then covered with some kind of upholstery material or hard board ?? Thanks again for your reply's, it will help me get started. Steve |
02-28-2014, 06:08 PM | #8 |
MEMBER EMERITUS
Get a Drake ( or Carpenter ) floor installed .
02-28-2014, 06:50 PM | #9 |
I don't know why, but I've seen those "angle braces" that you refer to both ways. I used Paul Bradleys pans to repair my trunk area, but Carpenters are more complete if you need to do the whole trunk section. Here are some pix of the 5 window rear floor and trunk.
02-28-2014, 06:53 PM | #10 |
Dennis Carpenter ended up with the complete coupe body reproduction that Bob Drake was initially a part of. Both will likely be reaping benefits of the sheet metal panels from the manufacturer of the bodies. I'm not sure if they are making the 5 Window version or the Business Coupe version but they might have the braces and the riser panels at some point.
There have been so many nays and yays about the Paul Bradley stuff that I would hesitate to recommend him. He does good work but takes forever sometimes. |
02-28-2014, 07:04 PM | #11 |
Joel, Thanks for posting those photos. Perhaps there was a design change at some point.
02-28-2014, 08:12 PM | #12 |
19Forty,
My '40 5 window has the same style rear braces as your '40. Probably a production design change. steve, That middle brace may have been relocated to make room for rear seating, etc., something I considered...but decided against. JFYI, Roy Nacewicz sells a really nice complete rear shelf assembly, along with many other correct nuts, bolts, fasteners, etc. |
02-28-2014, 08:41 PM | #13 | |
02-28-2014, 09:41 PM | #14 |
When I bought my '40, it was not stock, but "modified" by previous owners; '49 Mercury dash, GMC pannel truck seats, 389" Pontiac, '56 Ford rear, etc. Also, something I didn't realize until years later was that the door panels/moldings were deluxe, yet the hood/grill was standard. It's also an early production 85 HP car.
03-01-2014, 07:26 AM | #15 |
19Fordy......who is Roy Nasewicz and does he have a web site or email I can contact??
Thanks! Steve |
03-01-2014, 08:40 AM | #16 |
