Old 04-17-2024, 03:29 PM   #1
GPierce
GPierce's Avatar
Default Clutch Housing Crack
I have two clutch housings both with a crack in the same location.
I could not find anything on line about cracks in this location.
Both are cracked from the throw-out-bearing inspection cover outboard and up to the right side.
The picture is upside down.
One is all the way to housing flange the other is shorter. I stop drilled the shorter one and then used dye penetrate to check and see if I got the end of the crack stop drilled.
Are cracks in this location abnormal?
GPierce is offline   Reply With Quote
Old 04-17-2024, 09:17 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Clutch Housing Crack
I have a crack in my AA four-speed bell housing. I carefully cleaned the housing, followed the end of the crack and drilled the hole to prevent it from spreading. I believe mine was probably cracked from an accident from a previous owner. The bell housing was in near mint condition, which surprised me to find a crack. There’s virtually no wear in the bushings or on the clutch fork.
As long as you drill a hole at the end of the crack to prevent it from spreading.
I would not hesitate using it. You can see the crack in mine is much worse than the crack you have. The AA four-speed transmission is probably three times as heavy as the original three speed transmission.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-17-2024, 11:06 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Both are cracked from the throw-out-bearing inspection cover outboard.
Interesting they both cracked in the same location. Now my OCD is going to make me go out and check the ones I have for cracks .
