Old 09-04-2019, 08:15 PM   #1
tribouboys
Default Emergency Brake Cross Shaft Arms
Wondering if I have the Emergency Brake Cross Shaft Arms on correctly?? The arm where the rod attaches has a slight bend forward.
tribouboys is offline   Reply With Quote
Old 09-04-2019, 10:26 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Emergency Brake Cross Shaft Arms
If the rear of the frame is to the left in the picture, then it's correct.
Old 09-05-2019, 05:40 AM   #3
tribouboys
Thank you Tom, this is the passenger side arm shown in the picture.
Old 09-05-2019, 06:37 AM   #4
kenparker
kenparker's Avatar
The slight bend forward is to make the rod line up with the emergency lever on the backing plate which also has a slight angle to it.
kenparker is offline   Reply With Quote
Old 09-11-2019, 08:02 PM   #5
37 Coupe
37 Coupe's Avatar
The lever in the picture, and in particular the short shaft or pin that the fish eye clevis attaches to. Is it supposed to be 7/16" diameter? Mine look to be worn as does the clevis diameter so I don't know how you would fix the .od.? Mayby it is not an issue for wear on emergency brake? I don't understand how this part would wear,wouldn't movement only be when you engage the two levers,left and right with emergency brake handle?
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 09-11-2019, 08:21 PM   #6
Keith True
Keith True's Avatar
The wear is from constant rattling and vibrating,not from application.Not a problem for you unless you are shooting for perfection.
Old 09-11-2019, 08:24 PM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
It wears due to vibration. When gritty dirt is attracted and the park brake is activated, it wears the arm.
You ask how it is repaired, ...we made two fixtures that mount into the lathe that has an offset where the clevis end is in the centerline of the chuck. The arm is welded in the worn areas and then turned. Unless you are restoring multiples of these arms, just weld up the worn areas and use a grinding stone to make the shank round and to the size of the clevis. If you are off-center by a few thousandth it is not that big of a deal. This is a great source of rattles, so don't overlook restoring these arms.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-11-2019, 08:26 PM   #8
37 Coupe
37 Coupe's Avatar
Thanks for response. No not going to be a perfect car,far from it.I will however be installing the anti rattler springs that were missing on all rods.
Old 09-12-2019, 10:44 AM   #9
37 Coupe
37 Coupe's Avatar
The original poster's question actually made me look at mine more.So now I am wondering why the lever on mine seem to be the same bend forward like picture but also much more evident on passenger side than on driver side.What would require them to be different on a more exaggerated bend on passenger side?
