Old 11-03-2022, 04:31 PM   #1
sphooch
sphooch's Avatar
Cool Muffler clamp whats the secret
HI guys could use some advice here, i'm trying to get that muffler clamp around the muffler pipe and manifold connection. I have Les Andrews book , I have it in the correct position, and I have the copper gasket in place. just can't get it to mate up correctly. and how long are the bolts?? think i should drop the tail pipe so as to change the angle slightly?? I only have two hands is that the problem?? any advice is as always greatly appreciated. thanks THE HOOCH
sphooch is offline   Reply With Quote
Old 11-03-2022, 04:46 PM   #2
TMarsh
Default Re: Muffler clamp whats the secret
Put a hydraulic jack under it, that helps when you are by yourself.
TMarsh is offline   Reply With Quote
Old 11-03-2022, 05:37 PM   #3
Mike Peters
Mike Peters's Avatar
According to the Brattons catalog: Muffler bolts are 1 15/16" long. Also states that a 3 foot piece of pipe can be used to bend the muffler pipe where it attaches to the manifold so that it is in alignment with the manifold. In order for the connection to seal, there has to be a 360 degree mating surface.
I've tried bending the muffler to line up with the manifold and I can say that it really does work,, but be slow and careful.
Mike Peters is offline   Reply With Quote
Old 11-03-2022, 05:42 PM   #4
Mike Peters
And yes, put a jack under the muffler to hold it in place while attaching.
Old 11-03-2022, 06:09 PM   #5
Ray in La Mesa
The copper gasket is not original and the clamp is not designed for the added thickness. Make double sure the flange fits tight, the cheapo mufflers usually don't have a good flange. A jack under the front is your third hand. I use orange high temp silicone on the flange and 3 layers of heavy duty aluminum foil on the outside under the clamp,cut & folded into a 1' strip. The Aries muffler is much better even though it is more expensive, it also is made to Ford specs so cuts down on back pressure so engine runs cooler.
Ray in La Mesa is offline   Reply With Quote
Old 11-03-2022, 06:11 PM   #6
CarlG
CarlG's Avatar
Throw away that copper gasket.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-03-2022, 07:05 PM   #7
Ayers1
Ayers1's Avatar
I used a floor jack under the bend to hold it in place, then used a stock bolt on the hardest to reach position. I used a longer bolt on the other side and tightened them down. Once everything was set I removed the long bolt and put the 2nd stock one in. That was with the gasket.
Ayers1 is offline   Reply With Quote
Old 11-03-2022, 07:13 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Not original but Snyder's has a nice "NO Nut" clamp that sure makes life a whole lot easier... https://www.snydersantiqueauto.com/p...8536&cat=41736
I smear a little exhaust sealant https://www.amazon.com/Dynomax-35958...C151&sr=8-11on on the joint, no copper gasket.
Old 11-03-2022, 07:55 PM   #9
Conaway2
Conaway2's Avatar
As others have said, don’t use the copper gasket.
I recently used a MAPP torch to heat the bend the muffler inlet pipe enough so I could bend it to better align with the exhaust manifold. The muffler was out of the car for this.
I also use the short inlet pipe Brattons sells that drops inside the muffler at the inlet flange to help alignment with the manifold.
Be sure to have a good quality clamp - I like the one from Brattons. Also, some club members have taken their mufflers to a local muffler shop to have them re-flanged and been very happy with the results.
Good luck -
Jim
Conaway2 is offline   Reply With Quote
Old 11-03-2022, 08:03 PM   #10
nkaminar
nkaminar's Avatar
All good advice above. I can only add to put the clamp on snug but not tight then remove the jack and wiggle the exhaust pipe to get the best fit. Then tighten the clamp.
Old 11-03-2022, 08:18 PM   #11
sphooch
sphooch's Avatar
)K guys thanks alot , the copper gasket is going and i'll give it anther shot soon. if you don't here back from me I GOT IT DONE THE HOOCH
Old 11-03-2022, 08:47 PM   #12
Synchro909
Synchro909's Avatar
Those clamps were first made on this side of the world (RHD). The originals are more than a PITA. I simply tap one side of the clamp for a Helicoil and use shorter bolts.
The originals are almost impossible to position correctly and still have the clutch operable. Definitely NOT one of henry's better ideas!
Old 11-03-2022, 09:07 PM   #13
Bill G
Bill G's Avatar
Don't forget that the top and bottom portions of the clamp are different. If you put it on upside down, that could explain some difficulty.
Old 11-03-2022, 09:22 PM   #14
Vic in E-TN
If you decide to use stainless steel bolts in the Snyders clamp you will be making a big mistake. The SS will get longer than Grade 2 or 5 bolts at the high temperatures in this application and could relax the clamping giving you problems. It will go through some kind of changes with the heat cycles and cause galling of the stainless threads making removal difficult. Years ago I installed stainless steel nut and bolt in this area and getting it apart was a real problem.
Vic in E-TN is offline   Reply With Quote
Old 11-04-2022, 08:16 AM   #15
Ray in La Mesa
I also cheat a bit on the bolts. I insert the bolts into one side of the clamp and braise them to it, making sure they're straight. Then assemble it normally. only have two pieces to hold while adding nuts. Not for show obviously but you can't even see what I did.
Old 11-04-2022, 01:33 PM   #16
burner31
burner31's Avatar
So true...
Keith
Shawnee OK
'31 SW 160-B
Old 11-04-2022, 03:10 PM   #17
Ivan in southeast va.
Ivan in southeast va.'s Avatar
I like using aluminum foil to seal the two pipes together.
Ivan in southeast va. is offline   Reply With Quote
Old 11-05-2022, 10:19 AM   #18
DHZIEMAN
I was looking thru these posts to see if I should post my aluminum foil and muffler sealer combination to deal with the pipe to manifold connection. Have had mine working now with no leaks at the coupling now for about 3 years! And visually, it looks stock! The copper gasket is in my junk box!
DHZIEMAN is offline   Reply With Quote
Old 11-05-2022, 09:06 PM   #19
vern hodgson
That little piece of pipe is a waste of money. IMHO.
vern hodgson is offline   Reply With Quote
Old 11-05-2022, 10:24 PM   #20
[email protected]
modela@aol.com's Avatar
Some of the repro muffler clamps have to have the v groove at the ends be ground deeper with a Dremel or cut off wheel. Visually look at how the clamps mate up together and make any modifications to make sure they mate and make a perfect round hole for the manifold and pipe.
modela@aol.com is offline   Reply With Quote
