Old 01-02-2011, 12:51 AM   #1
glenn in camino
glenn in camino's Avatar
Default sport coupe top
Is there anything in print re. Model A sport coupe top construction. Specifically, the fit of the front header. I'm working on a late 31 that has had most of the wood professionally replaced by someone else and the header seems about 1'4" too tall.
glenn in camino is offline   Reply With Quote
Old 01-02-2011, 08:20 AM   #2
peters180a/170b
peters180a/170b's Avatar
Default Re: sport coupe top
The Restorer Magazine [ Volume 15 Issue 2] July -Aug. 1970 . No construction numbers but alot of info. on 30/31 Sport coupes. I know when doing my Phaeton, and the repro header was [way off from original size] TOOO thick,wide and front radius was well off. As Marco said to me they make it like a 2 X 4 piece of wood. I found a original header [front bow] and sanded the repro board down. It was well off from original.
peters180a/170b is offline   Reply With Quote
Old 01-02-2011, 10:25 AM   #3
glenn in camino
If anyone has vol 15, issue 2 of the Restorer, I sure would like to have a copy of that article on 30-31 sport coupes.
Glenn in Camino
[email protected]
Old 01-02-2011, 11:17 AM   #4
peters180a/170b
Glenn , if this is any help the #2 roof Bow Detail: from point[leading edge] to "under" #2 bow should be 18 inches tall. I restored a early 1930 Sport coupe. At that time [1982] LB's had a 2 tone gray T-14 top material which looked better then the top material on open cars[Tan]. [More correct looking was the gray].
Old 01-03-2011, 01:52 AM   #5
mot
Registered User
mot's Avatar
Glen
just take a spin down to Sacramento vintage ford and buy Volume 5 of the "how to restore your model A" published by the restorer magazine,the whole article is in it
tom
mot is offline   Reply With Quote
Old 01-03-2011, 08:53 AM   #6
hop up
hop up's Avatar
What size do you have for the front header? I have a Very Late 31 Sports coupe that I'm doing right now.
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 07-07-2014, 07:45 PM   #7
Gddecolret
Very good and*informative*exchange*..*Thank you!
Gddecolret is offline   Reply With Quote
