05-29-2012, 02:13 PM | #1 |
Starter Solenoid
Looking to replace the starter solenoid on my 1947 Ford convertible. A couple questions. The parts catalogs offer them with a steel case or a "bakelite" case; with or without FOMOCO script and with or without a "convenience button" on top. Which is the correct set-up in terms of original correctness?
Correct part number? |
05-29-2012, 11:00 PM | #2 |
Re: Starter Solenoid
The correct one for 47 is a steel case without the button I do believe.
05-30-2012, 05:06 AM | #3 |
The steel case units with the button are out of stock everywhere. For now the plastic case/steel bracket replacement type (with the button) is all that is available.
05-30-2012, 06:17 AM | #4 |
Beware, I paid extra for the ford logo metal with button & the nuts holding the cables are metric.I really thought with the logo it would be American made. Oh well.
Gary. |
05-30-2012, 09:01 AM | #5 |
I think button was early uses of the solenoid only, pre 1940 0r so, but there were also plenty of aftermarket ones with button.
05-30-2012, 09:41 AM | #6 |
Also, on positive ground systems, the large terminals MUST be correct to battery and to the starter. I learned this the hard way when I accidentally mounted one upside-down. |
05-30-2012, 12:27 PM | #7 |
It's actually just how the solenoid coils are grounded...insulated base, as in early Ford, has the hot side permanently connected internally and starts working when you ground the other end of that circuit via the small terminal. Grounded base is permanently grounded via its bracket and needs cannection to the hot side of battery via a two pole switch, as with Fords from about 1951 and most other cars. They don't actually care about polarity, they just need either the ground side or hot side of circuit completed depending on the type. In Early Ford, hot side is always connected but which side of battery is hot doesn't matter.
05-30-2012, 01:39 PM | #8 |
The 41 - 48 Ford Book says, " The solenoid case is zinc plated and may or may not carry the Ford script on the topside. A button on the bottom of the switches activates the starter motor as a convenience to the mechanic working under the hood."
That being said, if everyone is out, then good luck. |
05-31-2012, 06:11 PM | #9 |
I got lucky......Midwest Early Ford had some in stock.
08-30-2014, 09:43 PM | #10 | |
08-31-2014, 09:15 AM | #11 |
Here is how a solenoid works. Current is passed through a coil creating a magnetic field which causes the high current contacts for the starter to connect. There are a couple of ways for this to be done. One is to have an internal connection from the battery cable to one side of the coil and the single post is connected to a switch to ground. This is how an original or one made like an original works. There are some that have an internal ground and need power to the post. If you have one of these you need to wire it differently to get it to work. If you put an ohm meter from the post to ground and have fairly low resistance you have the latter. If you have an original you need to connect the battery cable to the side that shows low resistance to the post. Later cars have two posts where one supplies full voltage to the coil bypassing the resistor making the vehicle start easier.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
08-31-2014, 10:07 AM | #12 |
Thanks for the explanation and the reason why the new solenoid is not working the way the original did - I am on my way to test both, and hopefully this will solve the stuck starter problem! With my years of experience at this ( I have never changed either before ) I did not know if the problem was electrical or mechanical.
08-31-2014, 04:42 PM | #13 |
Most solenoids sold today are the "universal" type that have two small terminals. They are connected to the coil that pulls the relay. This allows it to be used in either a system that grounds the starter button or uses voltage to pull it. In the first case, one terminal is connected to the button, and the other to the battery side of the solenoid. In the second, One terminal is connected to ground, the other to the button or ring. C&G (800/266-0470) shows starter solenoids on page 140 of their catalog. If you want the original steel type with a button, order 01A-11450. If you want that one with a logo, add an "F" to that number. See the array in their online catalog www.fordparts.com
09-02-2014, 09:06 AM | #14 |
Thanks Supereal!
Now that I am getting familiar with this site, I am finding that all kinds of folks are having the same issues that I have been going through since 07 - some of them the trucks age, but also my lack of knowledge and simply not knowing what to ask of who, so many, many thanks ( ': o )) |
