Old 05-16-2012, 11:02 AM   #1
flatheadfan
flatheadfan's Avatar
Default Need a quick tire opinon
I am going to bit the bullet and get some radials for my '51. I am looking at 205/75/ R15 OR 215/75/R15. The 205 is the closest overall diameter to the standard 6.70-15. However, the 215 has a wider whitewall which is closer to the original whitewall width. The difference in diameter between the two is about 3/4"
Questions:
Any problems going to the 215 size (steering, speedometer)?
What is your preference Coker or Diamondback?
Thanks
Tom
flatheadfan is offline   Reply With Quote
Old 05-16-2012, 01:05 PM   #2
Cecil/WV
Cecil/WV's Avatar
Default Re: Need a quick tire opinon
I have Coker Classic radials and the feel like the have knots on them, even after balancing. I wouldn't buy another set. A friend bought Diamondback and is well pleased.
Cecil/WV is offline   Reply With Quote
Old 05-16-2012, 01:24 PM   #3
Ken Crans
Ken Crans's Avatar
Tom, I got the B F Goodrich Silvertowns for the wifes F-1. Very nice tire. I'd go with the 215's JMO Ken
Ken Crans is offline   Reply With Quote
Old 05-16-2012, 02:02 PM   #4
37don
I would defiantly go with Dimondback. They use new Modern tires with the latest technology and their whitewalls are unbelievably easy to keep clean. I have a friend with cokers on his 37 and a ton of weights to balance. Another friend has a 56 Tbird and has a bad thump which he can"t get rid of. Dimondbacks might be a little more money but well worth it IMO.
Don
37don is offline   Reply With Quote
Old 05-16-2012, 03:08 PM   #5
toby
toby's Avatar
The P205 75 X 15 are the widest you could go in the back. There is not much room between the body and tire with the stock wheel and that tire size.
toby is offline   Reply With Quote
Old 05-16-2012, 04:42 PM   #6
jdl
jdl's Avatar
Send a message via ICQ to jdl
I have 205/75/15 Diamond Backs on my 51 Coupe, they are a about a inch shorter than the 670/15 firestone bias on my 51 Victoria. I think 215/75/15 might be closer in size to the old 670/15. their is room enough on the rear wheel well for the 215/75 if you choose.
a 70 series might be too wide. the 205/75 is also good so it's a tough choice.
I love the Diamond Backs and would buy them again.
jdl
jdl is offline   Reply With Quote
Old 05-16-2012, 06:54 PM   #7
JT FORD
JT FORD's Avatar
Just installed a set of DB's 205"S on my 49 Ford, love them!
JT FORD is offline   Reply With Quote
Old 05-16-2012, 07:00 PM   #8
felix37
felix37's Avatar
Go with Coker! They have a no hassle guarantee! and a wider selection than anybody. period.
felix37 is offline   Reply With Quote
Old 05-16-2012, 07:32 PM   #9
makemc
makemc's Avatar
..I have 215/70/15 blackwalls on my 46,
no problems so for and love the ride..I do have a set of allstate white walls..600/16 bias that I ordered from Sears that I switch back and forth, but prefer the look and ride of the black wall radials
makemc is offline   Reply With Quote
Old 05-16-2012, 07:37 PM   #10
rick r
rick r's Avatar
running 215 on my 51 meteor. diamond back is my first choice
rick r is offline   Reply With Quote
Old 05-17-2012, 03:57 AM   #11
gmc1941
gmc1941's Avatar
Diamond Back is the best way to go in my humble opinion
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
