Old 10-24-2020, 10:45 AM   #1
OhioRick
OhioRick's Avatar
Default Bellhousing for a 368 Y Block Part #
I need to verify the part and/or the casting number for a Bellhousing of a Lincoln or Big Truck 368 Y Block. Could anyone please help?
Thanks. Rick.
OhioRick is offline   Reply With Quote
Old 10-24-2020, 02:52 PM   #2
KULTULZ
KULTULZ's Avatar
Question Re: Bellhousing for a 368 Y Block Part #
M/T or A/T?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 10-25-2020, 06:12 AM   #3
raceron1120
raceron1120's Avatar
Default Re: Bellhousing for a 368 Y Block Part #
Only # I could find was for a standard trans with OD, said to fit 57-59 368 & 383 cid.
Part # PB9M-6392-B.
I don't have a truck parts book for those years, cannot confirm if it's same as this item. I found it in the '56-'59 Merc Parts Book.
raceron1120 is offline   Reply With Quote
Old 10-25-2020, 06:20 AM   #4
raceron1120
Old 10-25-2020, 06:59 AM   #5
big job
big job's Avatar
If PB9M 6392-B STD & OD 368 Y and 383 MEL and 430 MEL share bellhousings: I
know and have done a FE or FT will work on a 383 / 430 then it should work on a 368.
big job is offline   Reply With Quote
Old 10-25-2020, 07:19 AM   #6
OhioRick
OhioRick's Avatar
Thanks everyone!!
Three speed manual.
File Type: jpg 9AA9AF2D-813A-4E92-B12B-E32232567E8E.jpg (71.6 KB, 17 views)
Old 10-25-2020, 09:28 AM   #7
KULTULZ
KULTULZ's Avatar
Post Re: Bellhousing for a 368 Y Block Part #
The MERC 368 only used the ST bell in specially prepared 1957 M-335 cars. Very limited production. CRAGAR made (also FORD vendor) a bell for conversion also. Very hard to find now. The truck bells are heavy cast and have the mounting ears on them. Hard to convert to pass car.
The 58/60 MEL had the same bell pattern as the FE. I have info somewhere describing adapting an FE bell to the 368. All of this has been discussed on the net and you may find info with GOOGLE. My machine took a nose dive and am still trying to resurrect lost info.
Old 10-25-2020, 09:38 AM   #8
KULTULZ
KULTULZ's Avatar
Unhappy Echo
... hmmpf ...
Must be an echo in here ...
Old 10-25-2020, 12:21 PM   #9
rotorwrench
rotorwrench's Avatar
The big Y blocks have their own bell pattern and most were made for trucks or the earlier Lincolns that still had the Lincoln Y-block. Once that MEL was out then there was a cross over with the FE so that they could use the same or similar transmissions till early 61. I don't think that parts book is correct putting a large Y with an MEL block. I'd guess it's a miss print. The Cragar or Stroppe bell housings were the only ones made for these big engines in cars.
There are several offerings for automatic transmissions to be adapted but no one is offering standard trans types. The truck engines were for F700 and F800 applications so no light duty bells were made for trucks and the big Y. An FE scattershield could likely be modified by welding and/or redrilling of certain holes. This would affect at least one of the alignment dowels and as many as six of the bolt holes. An adapter could be fabricated to fit the big Y with an FE block type bellhousing but it would likely require a crank spacer the same thickness to get the dimensions back. This won't be an easy adaptation but it can be done if a person wants to go there.
This link has a photo of the Cragar piece. They show up now and then.
http://forums.y-blocksforever.com/Topic84831.aspx
You might check with this guy but no guarantees since I don't know who he is.
https://www.fordbarn.com/forum/showthread.php?t=273611
Old 10-25-2020, 02:36 PM   #10
KULTULZ
KULTULZ's Avatar
Exclamation Re: Bellhousing for a 368 Y Block Part #
1 NOS Cragar #601 bell housing. Mint perfect new, still in box, fits 52-57 Lincoln engine to 49 to 64 Ford trans bolt pattern.
! NOS Scheiffer bronze faced aluminum flywheel Fits 52-57 Lincoln engine. Mint new perfect, still in box.
$1K for the pair, don't want to split up the pair
... damn ...
Yes Virginia, there is a Santa Claus ...
Old 10-25-2020, 02:44 PM   #11
KULTULZ
KULTULZ's Avatar
This car is what is being emulated -
-1957 Mercury Monterey M-335 -
File Type: jpg LYB - 1958 M-335 w MERC Rocker Covers.JPG (67.4 KB, 10 views)
Old 10-26-2020, 07:55 AM   #12
OhioRick
OhioRick's Avatar
Thank you for the information everyone.
