Old 12-27-2012, 07:39 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Help on lubricating Southwind Heater motor
I am attempting to rebuild an old Southwind heater. Stuck on how to disassemble the motor to lubricate it. I am sure the 60-70 year old grease/oil has long since dried up and it needs to be serviced. Looks like it should come apart, but how, and what to look out for. Thanks for any help you can give.
Happy Birthday to me. LOL
Old 12-27-2012, 09:01 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: Help on lubricating Southwind Heater motor
Happy Birthday Lawson. You might try to Google Southwind, maybe you'll find an exploded (no pun intended, LOL) view of one that will give you some idea re how to disassemble it.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-27-2012, 09:17 PM   #3
Lawson Cox
Lawson Cox's Avatar
I have it disassembled, all new parts installed but I would like to lubricate the motor before cranking it up. I have learned a lot about these old heaters. Pretty simple to work on if you have the new parts to replace the old ones which are crudded up with old lead salts. lol
Old 12-27-2012, 10:33 PM   #4
Henry/Kokomo
Henry/Kokomo's Avatar
How about a dry lubricant like powdered graphite? Or a lot of graphite mixed with a little oil? When the oil dries out, you'd still have lubrication. Just a thought.
Henry/Kokomo is offline   Reply With Quote
Old 12-28-2012, 12:39 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
I have had squeaking--binding blower motors made very happy with 1 drop of trans fluid ---20 years on some
Most small motors have bearings (bushings)made of powdered metal ---the space between the crumbs hold oil ---trans fluid can dissolve some of the dried oil and soak into the bearing ---if it is heated some with oil on it (or submersed and heated) the expanding air will bubble out, when it cools oil will be sucked in ----
Old 12-28-2012, 12:05 PM   #6
Lawson Cox
Lawson Cox's Avatar
I am trying to get it APART so I can do that.
Old 12-28-2012, 01:02 PM   #7
keith oh
keith oh's Avatar
Lawson, I have a complete set of installation instructions but do not see any mention of motor lubrication. Everything else is minutly covered, I guess they must have figured those instructions available from motor manufacturer. Keith Oh
keith oh is offline   Reply With Quote
Old 12-28-2012, 04:45 PM   #8
1931 flamingo
1931 flamingo's Avatar
HAPPY BIRTHDAY LAWSON ! ! ! ! !
Paul in CT
Old 12-28-2012, 05:05 PM   #9
jimTN
I just went thru my factory lit. and found nothing on servicing the fan motor. As late as 1985 you could get a new motor for $18.95, a big jump from 1950 when they were $4.95. Looks like the motor has two rods with nuts running thru it, will the caseing split when those rods/screws are removed?
jimTN is offline   Reply With Quote
Old 12-28-2012, 05:17 PM   #10
ken ct
Most likely its kinda like a FH starter with through bolts or screws. Might be kinda hard to put back together[the brushes ] ,good luck Lawson and HAPPY BIRTH DAY. ken ct. I think i would try to spray lube it with one of those little straw like tubes on a can of lube.Rather than take it apart.
ken ct is offline   Reply With Quote
Old 12-28-2012, 05:31 PM   #11
Lawson Cox
Lawson Cox's Avatar
I have tried several suggestions but wish Southwind had covered this particular item in their service material. I couldn't find anything about the motor either. I have done the best I can and have it back together. Hopefully, when it sits and dries a while, it will work. Will hook it up to battery and give it a whirl. I hope it will whirl anyhow. LOL
Old 12-28-2012, 08:58 PM   #12
Cool Hand Lurker
Cool Hand Lurker's Avatar
A lot of those old motors were throw-aways. You might be able to drill a small hole in the end cap of the bushing and inject some oil in that way. I have done this to other blower motors with success.
Cool Hand Lurker is offline   Reply With Quote
Old 12-28-2012, 10:11 PM   #13
Manuel
HAPPY BIRTHDAY Lawson!!!
Manuel is offline   Reply With Quote
Old 12-28-2012, 10:27 PM   #14
Lawson Cox
Lawson Cox's Avatar
That's a thought. At least it's worth a try. Thanks
Old 12-28-2012, 10:29 PM   #15
Lawson Cox
Lawson Cox's Avatar
Thanks. It was a good one. Lot of time spent with family and kin.
Old 12-29-2012, 09:53 AM   #16
georgewarren
I have had sucess dismantling throw away power window motors by gringing the rivets out and lubing the bearings with white grease. I drilled smal holes in the side of the case, held the brushes back with fishing line, reassembled the case, added new rivets, and cut and pulled the fishing line out; worked every time, and the motors lasted the life of my ownership. I like the idea of heating the oilite bearings in oil to drive out the air and pull in the oil, will try that next time! Good luck!
georgewarren is offline   Reply With Quote
Old 12-29-2012, 11:43 AM   #17
Kurt in NJ
Kurt in NJ's Avatar
Drilling a small is a method I have used before, but the amount of oil introduced needs to be small, flooding it will probably get oil on the brushes ---one or2drops can be enough----usually that end is where the brushes are
Old 12-30-2012, 11:00 AM   #18
keith oh
keith oh's Avatar
There is some super lubricant called Garage door roller lube that requires very little and hangs on very well. I am going to try it on my heater motor.
Old 12-30-2012, 02:56 PM   #19
Kurt in NJ
Kurt in NJ's Avatar
Garage doors need lubricant that stays in the tracks where you spray it, heater motors need lube that will penetrate the bushings---2 different needs in lubricant
Old 12-30-2012, 11:35 PM   #20
bgarrett
bgarrett's Avatar
Isnt Lawson Cox that famous guy?
bgarrett is offline   Reply With Quote
