Old 05-12-2015, 05:12 PM   #1
jerry of whidbey
jerry of whidbey's Avatar
Default won't start
took engine out re gasket it put engine back in and now I get no power to starter on mag or battery was told to re charge mag no idea how to do that some help please
jerry of whidbey is offline   Reply With Quote
Old 05-12-2015, 05:27 PM   #2
J Franklin
J Franklin's Avatar
Default Re: won't start
Is the battery fully charged?
Old 05-12-2015, 05:41 PM   #3
Jack Innes
Jack Innes's Avatar
As J Franklin suggested, charge the battery. Clean ALL of the battery cable connections really well - be sure all connections are bare metal to bare metal. Do not mess with the mag, it has no effect on the starter.
Jack Innes, Brooklin, Ontario
Jack Innes is offline   Reply With Quote
Old 05-12-2015, 11:41 PM   #4
jerry of whidbey
battery is clean and tight cleaned metal on ground have power up to the switch and wire block put in new switch checked all conections are tight starter does not even click
Old 05-13-2015, 06:05 AM   #5
Jack Innes
Jack Innes's Avatar
Did you clean the terminals on the starter button on the floor? If so try bypassing it with jumper cables. Wear safety glasses & gloves - there will be sparks! Again, the dash switch & the terminal block have nothing to do with the starter. The starter circuit is simply; Bat. to ground, bat. to button, button to starter.
Old 05-13-2015, 08:51 AM   #6
CharlieB
CharlieB's Avatar
The jumper cable test as suggested is your best bet as it by-passes everything else in the system. Connect the cables to the battery and hook up the positive to the starter connection. Use the neg. to complete the circuit. This prevents arcing/ruining the starter connection. There will be a bit of sparking. Hot battery is necessary.
CharlieB is offline   Reply With Quote
Old 05-13-2015, 04:59 PM   #7
jerry of whidbey
thanks every body for your help jerry
Old 05-16-2015, 02:49 PM   #8
jerry of whidbey
Smile Re: won't start
did as was told and followed battery up to block and starter. starter only had 1.6 amps took cable off and it stared to buss looked aat starter post and I forgot to put washer on put washer on started right up
