06-10-2016, 09:30 AM | #21 | |
Re: DO FE engines usually have a lot of blow by?
As clean and shinny as mine are on the inside, I suspect the Previous Owner did the same thing. Mot complaining, just commenting. I believe that I will "Follow your lead" and do the same. |
06-10-2016, 10:12 AM | #22 |
My guess would be stuck rings, PCV, or possibly a broken diaphragm in the A/T vacuum modulator that will suck transmission fluid into the engine through the vacuum line.
06-17-2016, 11:31 AM | #23 |
UPDATE: I've put about 300 miles (and another rebuilt carb) on this car since making the initial post. I opened the hood yesterday, with the engine hot & idling, and noticed that the blow by vapors coming from the oil filler cap have diminished quite a bit!
Perhaps it was just sticky rings, from sitting up so much. Perhaps the Risoline I added to the last oi & filter change helped also. Anyway, it's acceptable (to me) now. Thanks to all of ya'll who offered up opinions & advice. Last edited by rnch; 06-17-2016 at 11:44 AM. |
06-17-2016, 02:32 PM | #24 |
My car, 59' 361 FE sat for years before I got it. It had heavy blow by when I first got it. It doesn't have PCV but it got noticeably better after a few hundred miles. In fact, working on the second year of ownership, it gets better running every time I drive it. I am changing the oil frequently because it is really cleaning bad things out of the engine and depositing them in the filter.
06-18-2016, 08:24 AM | #25 |
I had one '64 Ford that smoked quite a bit, cleaned under the valve covers, new oil cap. This was my DD around 1974 to 1975, figured the rings were shot. Used straight 50 weight oil (summer only) and a can of Alemite CD2 every oil change. Really cut down on the smoke and consumption.
