Old 11-29-2012, 08:53 PM   #1
redmodelt
redmodelt's Avatar
Default Vacuume wiper paddle grease?
What grease do you use for the vacuum wiper paddle?
Thanks
Old 11-29-2012, 10:01 PM   #2
spike
Default Re: Vacuume wiper paddle grease?
vasoline works great to keep going...good luck
spike is offline   Reply With Quote
Old 11-29-2012, 10:10 PM   #3
redmodelt
redmodelt's Avatar
After I posted this I read the bit on Trico wipers that is posted here. That lead me to this;
http://modelabasics.com/wiper.htm
But this is a dry start up and Vaseline sticks in the back of my mind. But Tom was told no on that. ? I think we will go with the Vaseline for start up the do the oiling as outlined in the link.
Thanks
MarkG
The Model A Ford Works
502-282-2212
Old 11-29-2012, 10:32 PM   #4
Dick Deegan
Dick Deegan's Avatar
The only thing that I found worked is a silicone base O ring lubricant. You can buy it at pool outlets. It also depends on what the sealing material on your paddle is. Is it the original leather, rubber based?? Mine is rubber based and the vaseline just go absorbed into the rubber and didn't work that well. I tried various oils as well.
Dick
Dick Deegan is offline   Reply With Quote
Old 11-30-2012, 12:24 AM   #5
Marco Tahtaras
Marco Tahtaras's Avatar
These only apply to replacement wipers with fiber paddles.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 11-30-2012, 12:44 AM   #6
700rpm
700rpm's Avatar
I use Vaseline, and once in a pinch I had to use Vicks VapoRub because that was all I had with me in the wilderness. I've got original rubber paddles in all my cars. Oil didn't work for me.
Ray Horton, Portland, OR
Old 11-30-2012, 10:13 AM   #7
marc hildebrant
marc hildebrant's Avatar
I draw Marvel Mystery Oil into the wiper. It makes the wiper work great.
Marc
marc hildebrant is offline   Reply With Quote
Old 11-30-2012, 02:31 PM   #8
Marco Tahtaras
Original paddles were leather however they do wear out and need to be replaced. When they are good, neatsfoot oil is generally used. When I restored my original Roadster wiper and put it on the car I thought it was going to throw the wiper arm and blade right off the car!
Old 11-30-2012, 05:01 PM   #9
700rpm
700rpm's Avatar
Hmmm. Well, Marco, mine might be leather. They were so soaked with something that they looked like rubber. But leather makes more sense. I'll Have to look at them more closely next time I have to lube the wipers.
Old 11-30-2012, 08:40 PM   #10
Jerry Huntngton Beach
I use "vacuum grease" in my windshield wiper and Columbia shifter. Available at most industrial suppliers.
Jerry
Jerry Huntngton Beach is offline   Reply With Quote
Old 12-01-2012, 10:04 AM   #11
Merc Cruzer
Merc Cruzer's Avatar
I have used this and it has been great.
Merc Cruzer is offline   Reply With Quote
Old 12-01-2012, 10:23 AM   #12
steve s
steve s's Avatar
Back in the day, I successfully restored my wiper using a liberal coating of the same stuff that I used to make my hair look like this: Lucky Tiger Hairwax. It seemed just a bit softer than vaseline.
steve s is offline   Reply With Quote
Old 12-01-2012, 12:44 PM   #13
redmodelt
redmodelt's Avatar
That funny! Of the products I was thinking about when I made my first post, Butch-wax was in the list , Brill-cream although a little dab will do-ya, would be too runny.
