Old 07-13-2015, 01:49 PM   #1
smitty city
Default six cylinder starter
I am working on a 48 flathead six. I read that the starters are the same except the bendix gear is 9 teeth on the six and 10 on the v-8, is this correct? Also I pulled the starter and it has 10 teeth?? It started with the 10 tooth starter so what gives?
smitty city is offline   Reply With Quote
Old 07-13-2015, 02:34 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: six cylinder starter
Flat 6's use the same starter and drive as the flat V8, 10 tooth.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-13-2015, 03:13 PM   #3
smitty city
thank you
Old 07-14-2015, 03:04 PM   #4
amodel25
amodel25's Avatar
Not sure about '47 and earlier, but '48-'51 sixes use a 9 tooth drive. A 10 tooth will work but wears on the ring gear teeth.
amodel25 is offline   Reply With Quote
Old 07-14-2015, 05:20 PM   #5
Ross F-1
Ross F-1's Avatar
Well, I'm confused. Here's what the Truck Parts shows.
Old 07-15-2015, 07:35 AM   #6
amodel25
amodel25's Avatar
Not sure what they mean. My avatar was a 58,000 mile 6 cylinder car when I got it and it had a 9 tooth. I bought an original NOS Ford boxed 9 tooth off e-pay when I had the starter converted to 12 volt. I still have the box at home somewhere. I'll try to find it tonight. I bought a 254 engine complete (not sure what year)and another 226 from a '50 car and they both had 10 tooth drives.
Old 07-15-2015, 02:43 PM   #7
smitty city
do you guys think the 10 tooth starters in the sixes were replaced incorrectly?
Old 07-15-2015, 02:47 PM   #8
smitty city
the 48 F1 we are working on has been in the owners family for about 50 years ( they are the second owners), we pulled the starter and it has a 10 tooth gear, but could it be that it was replaced improperly sometime during the first ownership?
Old 07-15-2015, 03:48 PM   #9
DD931
DD931's Avatar
The green book is somewhat confusing - see P 496. No mention of later (H-series) sixes. So, I looked in my '48 - '56 truck book(s) and find references that can be interpreted to show both 9 tooth and 10 tooth pinions used in the 226 CI six. I think I would put back what was working. As a rule, Henry didn't change things just for the fun of it and commonly used the same accessories on both 6 and 8.
DD931 is offline   Reply With Quote
Old 07-15-2015, 03:52 PM   #10
DD931
DD931's Avatar
Sorry to be redundant - what I was looking at is what Ross has shown above (Post #5).
Old 07-15-2015, 05:35 PM   #11
smitty city
would it help if I counted the number of flywheel teeth?
Old 08-11-2015, 03:11 PM   #12
smitty city
thanks to all for sharing your knowlege
