Old 07-03-2021, 04:12 PM   #1
1930artdeco
1930artdeco's Avatar
Default Tranny off, how to remove flex plate?
Well got her off and set aside. Everything, even the ring gear is in great shape. I don’t think the tranny has ever been apart from the engine. But how do I get the flex plate off without destroying it? I hit the bolts with an impact gun and it didn’t even budge.
Also, this was at the bottom of the housing. To me, that is rear main oil leakage. Which is the main reason to get the flex plate off. So I can replace if need be.
Mike
File Type: jpeg 83311250-C7E5-4DDA-8007-3943CC1176D1.jpeg (130.4 KB, 43 views)
File Type: jpeg 0D79752B-A332-457D-B4DD-59537C2E147E.jpeg (186.4 KB, 48 views)
File Type: jpeg 65616D09-4E24-4479-8FE4-C791942CAE0A.jpeg (150.5 KB, 44 views)
1930 TownSedan (Briggs)
1957 Country Sedan
Old 07-03-2021, 08:10 PM   #2
darrell
Default Re: Tranny off, how to remove flex plate?
the flex plate is not hard to remove.use a socket and power bar.
darrell is offline   Reply With Quote
Old 07-03-2021, 08:11 PM   #3
KULTULZ
KULTULZ's Avatar
Question Re: Tranny off, how to remove flex plate?
Mike
You have the convertor assy off and are looking at the flex-plate itself? Can you show a photo?
We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ...
KULTULZ is offline   Reply With Quote
Old 07-04-2021, 01:30 AM   #4
1930artdeco
I tried the socket approach and I did was turn the crank. So I tried the impact gun and nothing. Maybe if I tried for a bit longer but I wasn’t seeing any movement at all. I will post a pic tomorrow. I just need it off so I can replace the rear main seal if need be. And I just realized i need to put the flywheel back on so I can use the starter to turn the motor over for my compression check-duh.
Mike
1957 Country Sedan
Old 07-04-2021, 04:53 AM   #5
KULTULZ
KULTULZ's Avatar
Post Re: Tranny off, how to remove flex plate?
You need to prevent the crank from turning, difficult as the ring gear is on the torque convertor on a 57.
Possibly use a bar to prevent the damper from turning.
Depending on the style of the flex-plate, you may want to replace it at this time.
Old 07-04-2021, 06:43 AM   #6
Ole Don
Ole Don's Avatar
It's time to step in to the garage, take a handful of scrap metal and make a new tool to hold the flex plate while bolted to the bell housing hole.
Ole Don is offline   Reply With Quote
Old 07-04-2021, 11:59 AM   #7
Herman Munster
Herman Munster's Avatar
I've used a box wrench as the holder on flywheels by putting a bolt through each end of the wrench.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 07-04-2021, 12:10 PM   #8
1930artdeco
Here is the flex plate. An original that has no cracking!
Mike
File Type: jpeg 90A4A452-6853-4C50-81B3-DDE87FA571ED.jpeg (146.9 KB, 28 views)
1957 Country Sedan
