10-15-2021, 05:57 PM | #1 |
Horn Wiring
I am looking for ideas/advice on how to wire a horn ground (or, if it is even possible) using a Lincoln 12 wheel -see photos- and a '35 Ford column with a solid shaft.
The car is being fitted with a Vega box and solid steering shaft so, there is no running a wire through the shaft. I am not sure how the original wheel, horn ring worked-what contacted what because the wheel hub is solid behind the horn ring. I can see that the horn ring/button is designed to be insulated from the steering wheel hub but, how did it work without a horn pin insulated from ground to make the connection between the horn ring and horn ground wire? This car is also converted to 12 volts, using an AAW harness with a horn relay built into the fuse panel. The OE 6 volt horn will not be used but, retained for looks only. A modern 12 volt horn will be hidden somewhere. I am starting to think this is not possible and may be resigned to a separate horn button. |
10-15-2021, 06:51 PM | #2 |
Re: Horn Wiring
If your steering shaft is a solid rod then there is no way of doing this unless you fabricated some kind of slip rings under the steering wheel. Use a separate mounted horn button I guess. Regards, Kevin.
10-15-2021, 07:04 PM | #3 |
Re: Horn Wiring
You question might be more suited to the H.A.M.B. where they do things like this more often.
10-16-2021, 04:16 AM | #4 | |
Re: Horn Wiring
Going with horn button on column, dash or, maybe even floor! |
10-18-2021, 10:23 PM | #5 |
Re: Horn Wiring
I have sort of the same problem on my '60. some one cut the horn wire to install an aftermarket wheel so no horn wire for my new stock wheel. I installed a momentary push button on the dash and epoxied a stock '60 knob on the button to blend in with all the rest of the knobs in the dash. so for only one person asked why I had an extra knob.
10-18-2021, 11:13 PM | #6 |
Re: Horn Wiring
If you have had a 41/42-46 car and you get shocked when pressing the horn and having your elbow on the open window. you could concluded the live wire is shorting. Be creative and make it happen. I'm not sure there is someone that has done it before. You might be the first. The concept is simple though. |
10-19-2021, 04:12 AM | #7 | |
Re: Horn Wiring
10-19-2021, 04:26 AM | #8 |
Re: Horn Wiring
Checkout Limeworks. I had a horn button I didn't like. I installed this kit now the horn ring works perfectly. https://www.limeworksspeedshop.com/R...-p/rhk1001.htm
10-19-2021, 01:12 PM | #9 |
Re: Horn Wiring
On my '39 Lincoln the steering shaft has hole running the length, through the steering box. This could take the hot wire and ground if needed. I don't think they had solid steering rods, but maybe.
