10-16-2012, 11:29 AM | #21 |
Re: Fairlane Question
There's a 55 Fairlane for sale on *bay and shows the front clip removed from the car exposing the front crossmember. You guy's have been saying that these crossmembers rot out. But why? It don't look anymore different than any other crossmember.
10-16-2012, 12:24 PM | #22 |
I can't answer why but just know that they do. Maybe not all of them but it's certainly something that should be scrutinized when contemplating purchasing one of these cars. Want to see bad? Here (sorry about picture size differences):
It was so bad that I had to chain the arms up just to move the car: Mine may be an extreme example but I've heard horror stories about how some have found 'home-made' fixes done by patching & undercoating them etc. Just something to beware of. The original xmembers have 'weep' holes in them supposedly to let moisture drain out but instead they seem only to trap salt and other debris inside, then rot out over time. Here is mine after the Xmember was replaced: Last edited by raceron1120; 10-16-2012 at 12:36 PM. |
10-16-2012, 02:24 PM | #23 |
Thanks for the photos. By the way, nice work!
10-16-2012, 03:25 PM | #24 |
The main reason the rust out is because the ends are open by the frame and the center of the x-member is lower than the ends. Water becomes trapped. If Ford had just put more than one hole in the center to allow any water that accumulates to drain then maybe then it wouldn't be such a problem (Mine has drain holes now).
But then of course over the years debris would clog the drain holes and it would rust anyway if the holes were not cleaned occasionally. How many of us routinely clean the drain holes in the doors and bodies of our cars?? Shoot the only major rust on my '55 Ranchwagon (See my avatar) is the right rear quarter panel and that was because someone in the last 55+ years stuffed newspaper in there??? not allowing the water to flow out. Last edited by Y-Blockhead; 10-16-2012 at 04:02 PM. Reason: Spelling |
10-16-2012, 10:07 PM | #25 |
Is this cross member the same in the '54 with the same rust issue? I heard 54 and 55 have the same frame.
10-16-2012, 11:13 PM | #26 |
10-17-2012, 04:38 AM | #27 |
Thanks, credit for the work on my car goes to John (streetdreams both here and on the HAMB). I'm not sure if the front Xmember is same for '54 & '55 but I'm quite certain the '56 is not same as the '54. There have been vendors here, on the HAMB and on ebay that sell replacement crossmembers so a search for specific years may answer your question about interchangeabity.
