Old 09-10-2012, 02:19 PM   #1
FatFndr
FatFndr's Avatar
Default 1939 Ford Coupe Seat Question
I am busy modifying a 1939 Ford Coupe. The wife wants a new seat with a headrest, something in the middle to rest her arm on and an adjustable back. I found a set of bucket seats, in good shape, at the local salvage yard from a 1996 Mercury Villager and am having a problem fitting them far enough forward to be useful - they need to go further into the middle but are currently bumping into the drive shaft hump and also need to be dropped about 1-2 inches. The decision to make is have a certified welder/fabricator modify the framework for the bucket seats OR go back the salvage yard and purchase a set of different bucket seats that will fit or a bench seat that will satisfy her criteria.
What seat will fit with very little modification? I would like to just drill new mounting holes if possible. Or can I add a headrest to the current stock seat, if so, how?
FatFndr is offline   Reply With Quote
Old 09-10-2012, 02:26 PM   #2
Vic Piano
Vic Piano's Avatar
Default Re: 1939 Ford Coupe Seat Question
I'd check some of the Street Rod magazines, they usually have ads in them for after-market/custom seats, you should be able to fine a bench seat with a fold down arm rest in the center (that coupe is kind of tight though, you might consider a portable/removable center are rest/drink holder, etc.) as well as a headrest option.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-10-2012, 04:26 PM   #3
charles in east texas
charles in east texas's Avatar
It might be cheaper to change wives. LOL
Charles
charles in east texas is offline   Reply With Quote
Old 09-10-2012, 04:28 PM   #4
Rebel Sympathy
I'd get a new wife and keep the car original. Or, at least, leave her at home. Don't mean to sound mean, but if the stock seat isn't bothering you.....
Mike
"There is no 'normal life'; there's just life." - Doc Holliday from the film Tombstone
Rebel Sympathy is offline   Reply With Quote
Old 09-10-2012, 04:45 PM   #5
cmbrucew
cmbrucew's Avatar
83 Malibu split bench power seat has headrests, fold down arm rest, and is @51" wide.
You would have to modify the base. Very comfortable seat for long trips .
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-10-2012, 07:23 PM   #6
FatFndr
FatFndr's Avatar
Bruce
Works good
Lasts long time
Thanks, I heard Dodge Caravan buckets fit as well, just need to cut out about 4" from the base, make up some mounting brackets and bolt in.
Old 09-10-2012, 07:51 PM   #7
39 STD
39 STD's Avatar
Fatfndr, I guess that a lot of seats can be modified to fit.
You have about 52" at the rear & about 45" at the front, + or -, to work with. Most bucket seat are somewhere around 20-22". Even more with arm rests.
Stock seat is about 50" rear & 44" front. Very plush when rebuilt with good padding.
Keep both, car & wife.
God is great, beer is good -----People are crazy
39 STD is offline   Reply With Quote
Old 09-11-2012, 09:09 AM   #8
Milt/Las Vegas
Milt/Las Vegas's Avatar
I bought a Glide seat for my 40 without armrests,but they make them with armrests.I'm thinking about sending the backs to them to have armrests installed.
Milt/Las Vegas
Milt/Las Vegas is offline   Reply With Quote
