I'm getting ready to set body on frame...seems like a good idea to put some contact cement between the pads and frame to keep the pads from moving or falling. comments welcome.
thank you, fordman |
yep
I just set my cab wood on my 39 p/u and used a spray adhesive to keep the rubber pad's in place on the wood. I could have used a nail like original. Nah
I didn't, but it can't hurt.
thank you
I didn't use any contact cement on mine because i used a car hoist to drop the body on the frame.....i guess it's a matter of personal preference....I found the frame and body moved some and shifted....
I use a small dab of contact cement for the very reason you suggest. I use a SMALL amount as you will likely find you will need to remove and / or add shims to make the panels / doors align properly. Too much glue makes it difficult to remove the pads once the body is atop them.
"Imagination is a crutch used by those who lack knowledge and intelligence ." B. Franklin |
I was thinking of tying the pads on with a piece of waxed string(dental floss) and then pulling it out after you get the bolts in.
I have done the string but you need a permanent fix, would glue next time .
http://www.flatheadted.com |
Good timing for this thread. I was think the same thing about gluing or using a caulk of some kind to keep the pads in place. I have a sedan body that I need to move from one frame to another. I am still noodling on the lifting part but there are several threads on that.
With the doors, trunk, glass removed, it required four adults to lift the body and put it on the frame. And I was an old geezer and couldn't help much. The bare body is not that heavy.
Great advice
#13 |
did you buy a kit or just copy the originals?
http://community.webshots.com/user/55dude |
#14 |
I bought a kit of pads for the frame that we supposed to be like originals. I bought a kit of bolts. the pads kit was better than the bolt kit.
fordman |
| Thread Tools | Search this Thread |
| Display Modes | |
