08-01-2023, 04:13 PM | #1 |
valve seats
managed to get 8 intake valve seats out with my mig. used the mig on the exhaust seats, wont budge, tried flux core, same thing. starting to wonder if there are any seats there. i know the later engines done away with valve seats, but never hear of mixing them. any ideas?
08-01-2023, 04:29 PM | #2 |
Re: valve seats
I believe there may have been engines with exhaust seats but no intake seats during the 8BA era, but I don't think the other way around would make sense. I could be wrong, but I seem to remember reading it somewhere.
I'd take a good hard look at the exhaust seats to see if they are in the block if it's an 8BA. |
08-01-2023, 08:39 PM | #3 |
Re: valve seats
True exhaust and intakes had seats in 48 and part of 49. then they dropped the intakes. till the end of 51. after that no seats.
Hope I got the dates right, memory not so good any mpre. Gramps |
08-01-2023, 08:56 PM | #4 |
Re: valve seats
Actually, I think the transition occurred a little bit later (the '51 model year).
08-02-2023, 07:15 AM | #5 |
Re: valve seats
My 8RT from a 52 appears to have exhaust seats. Can’t be positive, but sure looks like it.
I dig coal, which provides motivation for EVs. |
08-02-2023, 07:18 AM | #6 |
Re: valve seats
08-02-2023, 10:47 AM | #7 |
Re: valve seats
My 51 block doesn’t have hardened seats.
08-02-2023, 01:10 PM | #8 |
Re: valve seats
1st, i would like to correct my info. it is the exhaust seats that came out easy, not the intakes. 2nd i am certain the intakes have no seats. as much work i have put into them and not even a budge. called my local machine shop and they are backed up for 2 months! guess i am done for now. flatheads, gotta love em.
08-02-2023, 01:42 PM | #9 |
Re: valve seats
08-02-2023, 02:31 PM | #10 |
Re: valve seats
Maybe try a little witness mark with a sharp punch if you can its the block. Reply's are correct. But then model t s seats are machined in the block. My model t has intake & exhaust hardened seats (( because I put them there lol .....(original were so bad)
08-02-2023, 03:05 PM | #11 | |
Re: valve seats
Now all you have to do is figure out if you want to install exhaust seats during the rebuild. You probably will want to. |
08-02-2023, 07:27 PM | #12 |
Re: valve seats
My guess is that now that you've welded on the intake seats, you'll probably need to have them put in hard seats, and/or increase the intake valve sizes so you get to "good material" to grind a seat on. There are lots of options to work from.
08-03-2023, 07:15 AM | #13 |
Re: valve seats
I like to use the rotators on a "street " engine. They work well on cams up to350" lift. It's alittle tricky on the long valves.
Gramps |
