Old 06-12-2014, 08:43 PM   #1
46yblock
46yblock's Avatar
Default Questions on early 352 FE
It looks likely that the 352 in my '60 Tbird will need a rebuild. I am getting conflicting info about the early FE's vs. later. Can someone clue me in on the differences between the two engines?
I want to keep this one, not change to a 390. Things like common bearings, cams, rods, lifters, timing sets, cam bearings, head gaskets, etc. are of interest. I do know the early and late valves were the same. Heads are likely different. These heads and engine are the 300 HP Interceptor variety.
I am really having a time getting some straight info. Like combustion chamber volume. So far one dude seems satisfied to lecture more than instruct.
Maybe someone could steer me in a direction.
Thanks, Mike
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird
46yblock is offline   Reply With Quote
Old 06-12-2014, 08:45 PM   #2
Fordors
Default Re: Questions on early 352 FE
Google is your friend-
http://www.hotrodreference.com/81/fo...sting-numbers/
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery.
Fordors is offline   Reply With Quote
Old 06-12-2014, 09:08 PM   #3
46yblock
46yblock's Avatar
Thankyou. The linked chart reminded me to look in the High Performance Ford book by Reid. If shows confirmation that the COAE D head is 59-62 cc. That is good! I want to keep the dynamic compression as high as possible while still using 92 octane pump gas.
Mike
Old 06-12-2014, 09:53 PM   #4
46yblock
46yblock's Avatar
Originally Posted by Fordors View Post
Thanks! The chart reminded me to look at the Ford High Performance book by Reid. It confirmed the COAE D heads as being 59-62 cc. That is GOOD. I will try to keep the dynamic CR as high as possible on 92 Octane pump gas, and the original cam profile.
Old 06-12-2014, 10:11 PM   #5
TedEaton
TedEaton's Avatar
Camshaft in the pre '63 engines are the non-thrust plate design which uses a spring to hold the cam to the block. Finding a new non-thrust plate cam is a challenge but drilling/tapping the block for the '63 and later camshaft is doable so that the thrust plate can be used. You'll have to use the later timing set also with the later model camshaft. Ted Eaton.
TedEaton is offline   Reply With Quote
Old 06-12-2014, 10:18 PM   #6
46yblock
46yblock's Avatar
Ted, thanks. I had planned on having the original cam ground to stock specs at Oregon Cam, if that makes a diff.
Mike
Old 06-13-2014, 12:52 AM   #7
JeffB2
JeffB2's Avatar
I guess mre-books offers some coverage: http://www.mre-books.com/engine/bigblock.html
JeffB2 is offline   Reply With Quote
Old 06-13-2014, 10:08 AM   #8
scicala
scicala's Avatar
Thanks, Mike
Also if you go to the NHRA website and look for the engine blueprint specs, they list the head casting numbers, combustion chamber cc's, compression ratios, valve sizes, deck heights, carburetor numbers, etc. for the different years.
Old 06-13-2014, 11:39 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
Sal, That's good stuff to remember right there...
Old 06-13-2014, 08:48 PM   #10
46yblock
46yblock's Avatar
Very helpful info guys! Thankyou!
Old 06-14-2014, 02:52 AM   #11
JeffB2
JeffB2's Avatar
This is also a good place to check out:http://www.network54.com/Forum/74182/
Old 06-14-2014, 09:15 PM   #12
craig
why not bore the block .050 and use a std. bore 390 piston along with a 390 crank and rods. Use your original heads, etc., nobody will be the wiser, but you will gain some very noticeable torque
craig is offline   Reply With Quote
Old 06-15-2014, 06:33 PM   #13
46yblock
46yblock's Avatar
As time progresses, I am becoming more flexible on this project. Thanks.
