05-24-2015, 03:24 PM | #1 |
locking gas cap
does anyone know a supplier and the part number for a locking gas cap that will fit my 47 ford? someone keeps borrowing my gas. thanks for your help......george
05-24-2015, 04:00 PM | #2 |
Re: locking gas cap
Try BOB DRAKE.
https://www.bobdrake.com/ItemForm.aspx?Item=01A-18416-B |
05-24-2015, 08:32 PM | #3 |
Re: locking gas cap
Drain the tank
Put in five gallons of diesel |
05-24-2015, 09:46 PM | #4 |
Re: locking gas cap
i thought about posting up on top of my shed with a 12 gauge but better not kill anyone over gas although it is tempting.
05-25-2015, 09:01 AM | #5 |
Re: locking gas cap
Most V-8 parts vendors carry the locking cap. How about hooking up a Model T coil the gas neck? I'll bet they don't touch it after that experience.
05-25-2015, 10:06 AM | #6 | |
Re: locking gas cap
Security camera might be safer. Locking gas cap is less expensive but not as much fun, |
05-25-2015, 10:30 AM | #7 |
Re: locking gas cap
some great ideas.....i think i found a locking cap....thanks everyone.
05-27-2015, 07:20 AM | #8 | |
Re: locking gas cap
I had a model T coil hooked up to a car I had in the late '40's, my father showed me how to hook it up. Great fun when a carhop put a tray on the window sill, providing the tray did not contain several A & W mugs of root beer, or a gas jockey attempted to check the water, oil, especially if the ground was wet. On the down side, the "T" coil would drain the 6v battery very quickly, usually had to leave the engine running.
Bill.... 36 5 win cpe |
05-27-2015, 07:35 AM | #9 |
Re: locking gas cap
Get a cheap trail camera, happy hunting.
05-27-2015, 12:16 PM | #10 |
Re: locking gas cap
Blucar you still get fumes around the gas cap just take a good sniff. I'm not going to test out your theory.
05-27-2015, 01:23 PM | #11 |
Re: locking gas cap
years ago my high school buddy ran a fake filler to a gallon container which he pissed in and poured waste liquids in and every now and then he would get some fool trying to steal gas. his gas filler tube was in the trunk, safely locked up. might try that again.....
05-28-2015, 09:13 AM | #12 |
Re: locking gas cap
My comments were not based on theory, they were based on actual applications of a Model T coil on several vehicles, and the usage thereof.
05-28-2015, 09:23 AM | #13 |
Re: locking gas cap
I had a Dennis Carpenter locking gas cap on my '47 Ford Convertible however, it was a real pain in the butt to get the key and cap in and out of the gas door opening on the fender, that's before I had a garage for the car... There are Ford Gas Door Locks, they were an approved accessory, I'm sure you could locate one here on the FordBarn or on E-Bay, etc.
Imagination is more important than knowledge. |
05-28-2015, 11:06 AM | #14 |
Re: locking gas cap
locking gas caps are not really the answer, every seen the damage done by some one prying the cap off? a better solution is to get one of the spring wound coils, they have a large opening on one end and tapper down to about 1/4" on the other, you screw it in the fuel tank filler pipe, and push it down a few inches so you can get the pump spout in the filler pipe, once in almost impossible to get them out, does not restrict adding fuel , and you don't have to worry about losing a key, they have them on ebay for around $7
05-28-2015, 12:32 PM | #15 |
Re: locking gas cap
good ideas vic and westcoast....i like the coil idea best right now. thanks.
