Old 05-07-2024, 05:47 PM   #1
91A-77B
Default Disc brakes for wide-5 drums
I want to keep the wide-5s on my '37. Anyone aware of a source for a disc conversion? Currently running 46-48 F/M hydraulic set-up. Any help appreciated. Thanks!
91A-77B is offline   Reply With Quote
Old 05-07-2024, 06:17 PM   #2
rotorwrench
rotorwrench's Avatar
Default Re: Disc brakes for wide-5 drums
It might not be very practical to do a set up like that for the Ford wide 5. It could be done with adapters but it would change back spacing on the wheels. The adapters would have to clear the calipers too.
Old 05-07-2024, 06:39 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
Since the wide five pattern was and still is used for stock car racing disk brakes systems are readily available. One example Winters Performance In Pennsylvania has wide five disk brake options but its going to be pricey.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 05-07-2024, 07:28 PM   #4
91A-77B
Thanks, Ronnieroadster. Anyone know of any other sources?
Old 05-07-2024, 10:39 PM   #5
Newc
Newc's Avatar
Circle trackers also use 5/8th" lug studs. Usually will fit Ford original wheels tho. Newc
Old 05-08-2024, 04:28 AM   #6
deuce lover
deuce lover's Avatar
Speedway. For my 36 coupe. I bought the kit for 37-41 spindles with Mopar rotors with the 5X4.5 since I had the 57 Ford wagon 9" rear end.I then bought the adapters to mount the wide 5's.
deuce lover is offline   Reply With Quote
Old 05-08-2024, 07:39 AM   #7
91A-77B
Thanks, Deucelover. Speedway looks a lot better $$$$-wise than Winters!!
Old 05-08-2024, 04:42 PM   #8
hotcoupe
hotcoupe's Avatar
I know you said that you wanted to go to disc brakes, but have you considered using Lincoln Zephyr brakes. I installed '40 Ford brakes on my '37 1/2 ton, and I never felt confident in the ability to get the truck stopped in an emergency situation. I installed re-pop LZ brakes on the front and the difference is nothing short of amazing.
Tom
hotcoupe is offline   Reply With Quote
Old 05-08-2024, 06:17 PM   #9
V8COOPMAN
V8COOPMAN's Avatar
Tom
This is true IF you use the BOLING BROTHERS' repro parts - NOT the "SPEEDWAY MOTORS" parts. There have been several problems with the SPEEDWAY drums being out of round. The BOLING BROTHERS' drums are the 'nuts'! Plus, you can still use your '37 drum/hub package with the Boling Brothers' backing plate assembly if you wish. You DON'T need disc brakes on that car!!!
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 05-08-2024, 06:24 PM   #10
tubman
tubman's Avatar
I seem to remember that someone on the H.A.M.B. was making special wide-5 hubs for just this purpose. I did a quick look-see and couldn't find it. Maybe someone else here has a better memory.
tubman is online now   Reply With Quote
Old 05-08-2024, 06:27 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
That was POSSIBLY a piece made for tire/wheel balancing purposes.
Coop
T5 W/TORQUE TUBE
Old 05-08-2024, 06:29 PM   #12
tubman
tubman's Avatar
Coop
Nah, it was different. As I remember it, the guy was casting and machining specialized aluminum wide five hubs.
I believe he quit because of high cost and low demand. (I'm an expert on that after my condenser and Tachometer Driver debacles.)
Old 05-08-2024, 06:53 PM   #13
ssffnomad
ssffnomad's Avatar
Autocross = Disc Brakes
Non Autocross = Boiling Bros.
ssffnomad is offline   Reply With Quote
Old 05-09-2024, 08:41 AM   #14
91A-77B
Searched Boling Bros. Got Vintage Parts AZ. They are showing only non-wide-5 drums. No hubs. What's the magic with the repro L-Z set-up? Do you need everything: backing plates, shoe ass'y and hub/drums? Or just one or the other? Got the advice on Speedway. Tks.
Old 05-09-2024, 08:57 AM   #15
91A-77B
Please ignore my last post. I just remembered something about an ad for L-Z brakes in the V8 Times. Pg 109 of the March/April issue has the Boling Bros. info. Looks like the set-up is for 1940+ style wheels. So back to my search for a wide-5 solution. I'll call them to see if they can help. Meantime, any other sources? Thanks for everyone's input.
Old 05-09-2024, 09:22 AM   #16
deuce lover
Get these from Speedway and have the 5.5 pattern put in them
https://www.speedwaymotors.com/Speed...nch,29179.html
Old 05-09-2024, 10:10 AM   #17
91A-77B
Boling, M/T and Riley websites no longer in operation. I'll phone them today and report. Tks again.
Old 05-09-2024, 10:42 AM   #18
tubman
tubman's Avatar
One thing to keep in mind. I seem to remember that these use 5/8" studs on the wide five pattern. I checked the Speedway listing and it says they require their 1" bolts. From my days of racing modifieds, I think that means 5/8" studs.
They may fit, but measure before you buy.
Or maybe, get a disk brake setup that matches those adapters (5 on 4 3/4").
Old 05-09-2024, 11:20 AM   #19
hotcoupe
hotcoupe's Avatar
I should have included more info in my original post regarding LZ brakes. I used Boling Bros backing plates and the appropriate width brake shoe, they offer both 1 3/4" and 2" shoes. They produce quality parts, you won't be disappointed.
Tom
Old 05-09-2024, 11:27 AM   #20
deuce lover
They will fit as I used them on my 36.Have to buy the 5/8 lug nuts.
