Old 07-25-2012, 07:15 AM   #1
28Annie
28Annie's Avatar
Default Any recommendations for a basic test meter?
Can anyone recommend a decent, basic test meter that is good for a Model A electrical rookie? Analog or digital? I just want to be able to learn basic electrical diagnostics on my car, so I don't need something suitable for the Space Shuttle! Thanks
28Annie is offline   Reply With Quote
Old 07-25-2012, 07:48 AM   #2
rossofozini
rossofozini's Avatar
Default Re: Any recommendations for a basic test meter?
Get a digital multie meter and a battery hydrometer.
Last edited by rossofozini; 07-25-2012 at 07:48 AM. Reason: maybe a test light too
rossofozini is offline   Reply With Quote
Old 07-25-2012, 07:56 AM   #3
Farrell In Vancouver
Farrell In Vancouver's Avatar
28Annie, I have a really great digital volt/ohm meter that I use on everything......accept the A. The open ignition tends to make the digitals a little snakey. I bought a cheap analog for under thirty bucks that I use on the Fords. It's harder to read because the meter face is small but far more accurate. If I had my druthers I would by another with a larger meter. For most diagnostics you can get by with a cheap test light and probe.
Farrell In Vancouver is offline   Reply With Quote
Old 07-25-2012, 07:58 AM   #4
MrTube
MrTube's Avatar
I highly recommend a Fluke digital multimeter (DMM). Be warned the price can be anywhere from $100-300 typically but they are accurate and built to last.
I personally use a Fluke 179 and a Simpson 260 7P depending on what I am working on.
You will find the more expensive digital meters are much faster and far less annoying to use than the cheaper ones.
MrTube is offline   Reply With Quote
Old 07-25-2012, 08:28 AM   #5
Jim Mason
Jim Mason's Avatar
cheap analog multimeter. Mostly you will be testing continuity, and precise measurement isn't needed...fwiw,jm
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 07-25-2012, 08:33 AM   #6
Jeff/Illinois
Jeff/Illinois's Avatar
We used Fluke meters troubleshooting John Deere combines and I say they are the best.
However, there were several times that I would lay one on top of a steer tire and forget it and then my partner would start the combine up and back it out of the stall. They don't hold up well under 10 tons of combine. Make kind of a sickening 'crunch' sound when they get run over. The boss was pretty cool about it. He always ordered several extras and had them locked up in the tool room.
Old 07-25-2012, 08:35 AM   #7
28Annie
28Annie's Avatar
So the "cheap test light" is just for checking continuity, correct?
Also, many charts showing the electrical system for a Model A are available, but is there a good reference for showing what you should have for voltage at each connection throughout the system? For instance, what should the output voltage be at each side of the generator cutout switch or at the terminal block?
Old 07-25-2012, 08:38 AM   #8
MrTube
MrTube's Avatar
Old 07-25-2012, 08:43 AM   #9
Richard Wilson
Richard Wilson's Avatar
I agree with Jim. For basic Model A electrical trouble shooting I have used a $15 multitester (not digital) bought at the local hardware store for over 30 years and never felt like I needed anything more.
Richard Wilson is offline   Reply With Quote
Old 07-25-2012, 08:48 AM   #10
roccaas
roccaas's Avatar
Auto ranging is nice if you've got the $$'s. No switching!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 07-25-2012, 08:49 AM   #11
Mitch//pa
i agree with the fluke meter on it is a button to smooth out the reading so its not jumping around. but if your looking for cheap here it is tom W posted about this meter previously so he may have experience with it...
http://www.ebay.com/itm/A-W-Sperry-S...item20b8bf1cfe
Old 07-25-2012, 08:55 AM   #12
gilitos
gilitos's Avatar
There are plenty of situations in auto troubleshooting when analogue meters are easier to read, for example in poor light or when the meter is in your peripheral vision and you can see the needle position but couldn't read a digital number. One important difference between digital and analogue meters is how much they load the circuit you're testing: the analogue meter takes a tiny bit of current to move the needle; the digital meter takes almost zero current. This is important when you're troubleshooting solid state circuits but means nothing when working on a Model A.
gilitos is offline   Reply With Quote
Old 07-25-2012, 09:02 AM   #13
JoeWay
JoeWay's Avatar
Some time ago Tom Wesenberg recommended the Sperry SP-152A. They're offered on Amazon for about $10. I bought three to spread around and keep one in the Tudor tool set.
Joe
(Hah--took me too long to find the meter and the photo link--gotta be quick around here.)
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 07-25-2012, 09:03 AM   #14
28Annie
28Annie's Avatar
This is all helpful, guys but I have to narrow this down to what's needed to get me started:
1) Test light for continuity; do I need a separate one or can/should I just use the multimeter?
2) A recommendation on a reasonably priced ($50) meter
3) A chart, book or website posting that shows what the voltage should be at each electrical connection throughout the system
Thanks
Old 07-25-2012, 09:14 AM   #15
28Annie
28Annie's Avatar
Wow - That Sperry meter is yard-sale priced! I do like the idea of having an extra one to keep in the "under the seat" road bag.
Old 07-25-2012, 09:19 AM   #16
JoeWay
JoeWay's Avatar
1) I have test lights, but 98% of the time I use the multimeter.
2) There aren't many new analog meters in the $50 range--those are almost all digital. The Sperry (or similar) is adequate. If you really want to spend $50, search ebay for a Simpson 260. I have a couple and they are very good, but they're also large and heavy.
3) Model A electrics are very simple. Generally speaking, you should see battery voltage on the battery side of every load, and ground on the other side. Voltage drops should be very minimal. Even a diode cutout only drops a few tenths of a volt.
Joe
1929 Tudor
since 1962
Feather River A's
Old 07-25-2012, 09:33 AM   #17
Jerry Parr WI
Jerry Parr WI's Avatar
I have several and also recommend the $10. to $15. analog for trouble shooting. Digital is great for determining exact values but the are useless around a running Model A. Analog also is much better for go-nogo testing. I find them at Home Depot and cheaper at swap meets. Keep one in each car and one on each bench. I do also have a $10. digital that I use on rare occasions. The expensive ones stay in the drawer and seldom get used.
Jerry Parr WI is offline   Reply With Quote
Old 07-25-2012, 10:22 AM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
Joe
What Joe said! I have three of these Sperry meters, just so I don't have to look too long to find one. You can use it to measure up to 20 amps and it also has 1.5 and 9 volt battery checks, as well as all the other common ranges for amps, ohms, AC volts and DC volts. Check on ebay for "SPERRY SP-152A and you can have one delivered to your door for just over $13. It's my favorite meter, and my expensive Fluke just sets on the shelf.
BTW, this meter also has a buzzer continuity test.
Old 07-25-2012, 10:22 AM   #19
Napa Skip
Napa Skip's Avatar
What I would recommend is on the left (a simple analog multimeter and an inexpensive continuity tester, along with a couple of extra, clip-on test leads). The multimeter will come with a simple instruction book showing how the multimeter can be used for measuring DC (direct current) voltages and resistance (such as to ground).
What I would not recommend - due to bulkiness and cost - for the garden variety electrical work done on the Model A is on the right (a Simpson 260).
I don't think I paid more than $25 in total for what is on the left; I can't remember what I paid for my Simpson 260 in the 1970's, but even then it was far more than $25. Nice instrument (as is the Tektronix dual-beam oscilloscope, not shown) but, imho, a bit of overkill for what will ail your Model A, electrically speaking.
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 07-25-2012, 10:33 AM   #20
Tom Wesenberg
Also, after you buy the meter, go to the local Goodwill or other second hand store and you can find a nice carrying case for about a buck or so. You might even find one cheaper at a garage sale, but for a buck you can't drive around much to look.
