Old 02-17-2017, 12:34 PM   #1
Chris Nelson
Chris Nelson's Avatar
Default timing
Can someone tell me the timing for a 50 Ford flathead with an Isky 77B cam and mechanical electronic Mallory ignition?
Thanks; Chris:
Chris Nelson is offline   Reply With Quote
Old 02-17-2017, 03:46 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: timing
Put it on the pin and let the distributor do the rest.......
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-17-2017, 06:03 PM   #3
flatjack9
flatjack9's Avatar
Default Re: timing
I would bump it about 2 more degrees. Even a mild cam like this has more overlap, so there will be some charge dilution and so could use a little more advance.
Old 02-17-2017, 07:58 PM   #4
Ol' Ron
Ol' Ron's Avatar
Default Re: timing
You might want to see whats in the distributor before you try it. Initial timing is not very important, just so long as the engine starts. Next run it up to 2000-2400 and check advance curve. Then you can determine what you want or need. With vacuum, I like about 28 degrees. However the mechanical should be limited to around 22. A closed combustion chamber will help here.
Old 02-17-2017, 11:48 PM   #5
flatjack9
flatjack9's Avatar
Default Re: timing
I do think initial timing is important. But as noted, the advance curve must also be taken in to account for the proper overall timing. With my crab distributor, I run more advance just to help out the part throttle as that is where 90% of my driving is done. Ideally I would like vacuum advance also, but I think the only place I've seen it done is in JWL's book.
