10-09-2014, 12:19 PM | #1 |
Y-block & stainless steel bolts?
I'm about to start on final reassembly of a y-block engine. Several of the bolts around the water pump and a couple others for the timing cover/motor mount are fairly corroded and I'd like to replace them all.
What is your opinion on getting replacements. I'd rather not size/length match them for the cheap imported ones at the hardware store. I could probably find another engine to borrow them from, but they'd be just another used set. There's an outfit on epay that sells a set of new stainless steel bolts for mounting all the outside parts onto the block. Are the stainless ones better around the water pump or exhaust ports than regular steel bolts? Is there a reason I'm missing that I should or shouldn't get a set of the stainless ones? Thanks. Last edited by dmsfrr; 10-09-2014 at 10:33 PM. |
10-09-2014, 06:14 PM | #2 |
Re: Y-block & stainless steel bolts?
I bought two sets, for two differmt Y block. Used anti-seize. I've got the bird motor down to a bare block, no corrosion on the bolts, the aluminum parts, or the iron. They're fine for brackets, timing cover, etc. Headbolts, mains, rods, etc. I stay with known brands. Usually ARP. I use their header bolts, also.
10-09-2014, 10:45 PM | #3 |
I see nothing wrong with the stainless steel bolts. I use them here and there myself, while they are not up to a grade-5 strength wise, you'd be okay for what you intend to use them for. Anything that passes through a water jacket, dip it in something like Indian Head shellac so it won't weep coolant.
10-10-2014, 08:06 AM | #4 | |
10-10-2014, 04:56 PM | #5 |
Personally, I only buy grade 8 fasteners, if they are available.
10-10-2014, 07:28 PM | #6 |
10-10-2014, 08:16 PM | #7 |
I bought a set of stainless engine bolts off ebay (some time ago so don't know who the vendor was) and they have worked fine for the 7 years they have been on the car and I use the car a lot.
Okay for everything except the heavy duty stuff like rod and main bolts, front end and other high stress applications. However, Totally Stainless has what they call high strength stainless. They also have engine kits. 800-767-4781 |
10-10-2014, 09:54 PM | #8 |
Mine are all marked grade 5. I think they were Totally Stainless.
Please excuse me for going slightly OT. A few years ago, I bought some 1/4-20 bolts and nuts for a boat application at a big box store. As I put them together, they were "loose", as in the bolts were small, or the nuts were big. I went down to the marine store, paid twice as much, and they seemed "tight". I don't want to name any country, but if you're building a billion of them, you save a lot of stainless by working the outside of the specs. I've also used SS in high corrosive areas (acid and caustic), and the cheap ones rust. There's different grades of stainless. You sometimes get what you pay for. |
10-11-2014, 08:01 AM | #9 |
Regular stainless are an 18-8 composition, 18% chrome and 8% nickel, aka 304 stainless. There is also 316 alloy which is almost always used in harsher environments and expensive.
The Ace Hardware by me has a good stainless selection and is 1/2 the price of West Marine. I always check the fit between the nut and bolts, agreed that the offshore ones tend to be pretty crappy. |
10-11-2014, 10:02 AM | #10 |
This is all very helpful information.
I knew I asked the right folks. Thanks much, I appreciate it. Dennis |
10-14-2014, 02:58 PM | #11 |
I use ARP, let me say that again ARP brand stainless fasteners on particular stressfull points on my Harley and FORD engines, both in six and twelve point flavors. I also use ACE Hardware small stainless screws, nuts & washers for interior trim, not highly stressed, in all cases use anti-seize or you may have problems on dissassembly. Beware the no-name offshore pieces. Look closely at what you are buying, the appearance is an indicator of quality to some degree....If it has cut threads and looks like crap, it probably is. Another clue: Sstandard American threads (more or less) + metric head size = NFG.....Best wishes.....RooDog
