Old 03-02-2015, 05:06 PM   #1
adileo
adileo's Avatar
Default 1939 Deluxe head bolts
Ok - I know my 39 has bolts securing the head and that is not the way the car was built in 39 - that said........
My question is - under the green paint, it appears like the bolts are brass. Can that be?
Either that or they are 14k gold bolts and Im a little richer today.
adileo is offline   Reply With Quote
Old 03-02-2015, 05:14 PM   #2
JSeery
JSeery's Avatar
Default Re: 1939 Deluxe head bolts
Are they the gold/bronze grade 8 bolts? I'd tell you you need studs, but then some other on here (Ron) would disagree!
Grade 5s are greenish, grade 8s are gold.
Old 03-02-2015, 05:23 PM   #3
adileo
adileo's Avatar
They seem to work fine - no leaks so they will remain as is... Gold bronze grade 5 is that what would have been used? All I can say is where there's no paint, I see bronze / gold bolt
Old 03-02-2015, 05:25 PM   #4
JSeery
JSeery's Avatar
Take a look at a hardware store and see if the look similar and I corrected the post, should have been grade 8!
Old 03-02-2015, 05:26 PM   #5
Kube
Kube's Avatar
I am guessing the bolts used on your '39 were taken from a later Ford engine and simply installed and painted over. That would explain the "gold".
Old 03-02-2015, 05:29 PM   #6
adileo
adileo's Avatar
No this is not gold paint
Old 03-02-2015, 05:34 PM   #7
adileo
adileo's Avatar
JS think you nailed it I googled gold bronze grade 8 and that's what they look like
Thx
Old 03-02-2015, 05:39 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
Most likely yellow cadmium plating.......not un-common on bolts. How many radial marks or lines are on the bolt heads? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 03-02-2015, 05:45 PM   #9
adileo
adileo's Avatar
3 lines look like a big Y
Old 03-02-2015, 05:47 PM   #10
flatjack9
flatjack9's Avatar
That would be a grade 5 bolt.
