03-02-2015, 06:01 AM | #21 |
Re: Kit for mating juice brakes to early spindles-Richard's Early V8 garage?
Isnt Tim going to have to change his front drums/hubs to a 40-48 style with drums on the outside also?
03-02-2015, 07:15 AM | #22 |
03-02-2015, 08:29 AM | #23 |
03-02-2015, 10:39 AM | #24 |
speedways kit is a piston ring, just installed my kit and the ring snaped in 3 pcs. cast.
03-02-2015, 10:43 AM | #25 |
03-02-2015, 10:44 AM | #26 |
And tack weld the adapter plates to the inside of your backing plates. If you want to see an example, just ask (as I just took my plates apart to get them ready for paint). B&S |
03-02-2015, 10:46 AM | #27 | |
I would like to see a picture. I'll PM you my e-mail address. Thanks, Tim |
03-02-2015, 11:58 AM | #28 |
03-02-2015, 12:00 PM | #29 |
03-02-2015, 01:35 PM | #30 |
Here is a pic of the Lockheed front backing plate on the spindle. This is after I plug welded and re drilled the holes. You can see the adaptor ring in the middle.
03-02-2015, 01:54 PM | #31 |
You guys that are welding up the holes, are you using TIG or MIG? I like how clean it looks with the holes plugged and re-drilled.
03-02-2015, 02:29 PM | #32 |
this is 34 to 39-40
03-02-2015, 02:34 PM | #33 |
I thought about doing this as well. My concern was messing up a set of '32 spindles by generating too much heat from the MIG. If I had a TIG, I would go this route.
Maybe my concern is unfounded, but love to hear from others who added width to the spindle sides v. modifying the backing plate. |
03-02-2015, 03:24 PM | #34 |
I used the mig to plug up my holes. Welding up the spindles like that scares me too. Really a lot of work for not much gain in the end. Plus i am trying to keep it so we can put the original mechanical brakes back on in case I become a total purist some day
03-02-2015, 03:52 PM | #35 | |
The difference between mig and tig would be minimal if you are welding 4 holes the amount of heat concentrated would no different .( the spindles are Ford drop forged very strong .) this car was imported from the US so these were done possibly 30 years ago .what I am doing here is duplicating what was done to get it complied as the spindle race had been welded on the one of it ..,I later cut this of to restore it as I only welded one side
03-02-2015, 04:12 PM | #36 |
Here's the back ,By plug welding you are getting close to the edge your not adding any material
03-02-2015, 04:23 PM | #37 |
The backing plates from MT Car Products come in both spindle patterns. Those Bendix style brakes also work very well on front only. Interesting that some still choose to use those inferior Lockheed brakes. The '39-'48 cars I've owned all have gone Bendix. Well not all. The '40 woodie I had was stolen before I had a chance to convert it. Crap brakes is a common argument when our government friends try to regulate our old cars off the road. Good Luck: Fred A
03-02-2015, 04:47 PM | #38 |
The Lockheed can work ok providing they are adjusted to the book and a suitable lining fitted ,the car here had poor brakes until I put a better quality lining on them ,the tendency in the 70-80-90-was to fit linings suitable to power booster system .
03-03-2015, 07:14 AM | #39 |
Here are Richard's conversion plates installed on a set of 39-48 backing plates (which have been modified for Bendix style brakes by Bass). The adapter plates have a few small TIG tack welds to hold them in place - works out really well. One could also plug weld the original bolt holes - would clean it up a bit more.
Dale Backing1 copy.jpg Backing2 copy.jpg Backing3 copy.jpg |
03-03-2015, 12:23 PM | #40 |
[QUOTE=Bored&Stroked;1043809]Here are Richard's conversion plates installed on a set of 39-48 backing plates (which have been modified for Bendix style brakes by Bass).
QUOTE] Anything that Bass touches or has a hand in turns-out to be a work of art. DD |
