04-28-2023, 03:38 PM | #1 |
Available rear axle ratios in 1948 V8 car....
Hey Guys! What rear axle gear ratios were available from Ford in a 1948 V8 convertible? Thanks in advance! - F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
04-28-2023, 03:46 PM | #2 |
Re: Available rear axle ratios in 1948 V8 car....
I dont know all the ratios, BUT ,I have a 4,44-1 that is in great condition for free if any one wants it.
Lawrie |
04-28-2023, 05:37 PM | #3 | |
If I'm not mistaken, the 3:78 was the standard, the 4:11 being optional.
04-28-2023, 05:57 PM | #4 |
Also 3.54.
04-28-2023, 06:08 PM | #5 |
04-29-2023, 07:21 AM | #6 |
04-29-2023, 11:01 PM | #7 |
Columbia ratios? 4:44 and ?? Newc
05-01-2023, 01:19 PM | #8 |
Why was the 4:11 an option. for trucks; half ton, one ton?(Tudor, Fordor for those with 'extended family' and a full trunk) . . . thank you!
I once bought a '36 half-ton not thinking about the gear ratio. At that time I had no idea about gear ratios; that they existed. I soon learned. This '36 had a 4:11. I peeled through ads; found a 3:78. WOW! Great in town, great on the country roads! |
05-01-2023, 04:07 PM | #9 |
For whatever it's worth... My 47 (convert, heavy) came with 3.54. A buddy's 48 Merc (convert) came with 4.11. In my opinion, my 47 with 3.54 was a slug around town. I 'hotted up' the engine, then it was more drivable. The 48 Merc was good at the stoplight, but ng on the road. We changed the 48 to 3.78 with a Columbia. With the 3.78, it was much more friendly to drive. Never did hook up the Columbia, but, at least it's there for some future day...
05-03-2023, 09:18 AM | #10 |
Another option would be to keep the 3.54 and go with the wide ratio (29 tooth cluster) transmission. It is about 10% lower in first and second thus acting like a 3.78/standard ratio in those gears.
05-03-2023, 09:26 AM | #11 |
If you are going with a 3.54 rear end use these transmission gears. I have this set up in a '47 tudor and it's great driving, anywhere.
05-03-2023, 01:33 PM | #12 |
Again, for whatever it's worth, my 47 came with the 29 cluster already installed. (as well as the 3.54 already mentioned.)
05-03-2023, 02:27 PM | #13 |
