Old 10-25-2011, 09:33 AM   #1
C26Pinelake
Thumbs down 29 starts and after few seconds backfires and
1930 Sport Coupe - Yesterday it was running for an hour and today After it starts it backfires a couple times and stops. It will immediately start again but it repeats the backfire and stop. Up until now run it all summer and run like a new one. Does it sound gas ( tank half full ) or ignition and if ignition where should I start looking ?
Thanks Wayne
C26Pinelake is offline   Reply With Quote
Old 10-25-2011, 11:17 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: 29 starts and after few seconds backfires and
I'd start with fuel flow to the carb, then ck points/cond.
Paul in CT
Old 10-25-2011, 11:22 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I always start with the easiest checks first. Holding the coil wire 1/4" from the head nut and looking for a hot blue spark is probably the easiest check. However, in this case it sounds like a fuel related problem.
Not a problem, as either spark or gas flow only takes a minute or two to check. Just do the check first rather than start by throwing new parts at the problem and hoping for the best.
Old 10-25-2011, 11:50 AM   #4
johnbuckley
johnbuckley's Avatar
Yes, check the spark as always as the first step . Back firing through carb is often sign of fuel starvation, whilst it stops the fuel is seeping through to refill the carb sufficiently to restart. - Check , filters if you have any, sediment bowl, and blow through fuel pipe to dislodge any rust particles sitting in the outlet of the tank.
johnbuckley is offline   Reply With Quote
Old 10-29-2011, 09:45 PM   #5
C26Pinelake
Could it be the timing ?
Old 11-02-2011, 05:51 PM   #6
Jack '29 Sport Coupe
Jack '29 Sport Coupe's Avatar
Did you do anything else like remove the carburetor, or do anything to the gas lines?
If so, you might want to make sure the ferrules are not too far up on the lines because that's one thing that stops the gas flow quicker than you can blink your eye!
Jack
Cincinnati, Ohio
Jack '29 Sport Coupe is offline   Reply With Quote
Old 11-02-2011, 06:06 PM   #7
JBR
JBR's Avatar
Check the spark plugs. Make sure they aren't fouled.
Jon
JBR is offline   Reply With Quote
Old 11-04-2011, 07:07 PM   #8
Ray With
Ray With's Avatar
Had the same thing and found restricted fuel flow. The shut off valve in the tank had some crap in it. Took it off and flushed it all out and been fine every since
Hotrodchat's Picture Gallery
26,000 pictures to keep you looking
Ray With is offline   Reply With Quote
Old 11-04-2011, 09:17 PM   #9
smurph
smurph's Avatar
I had a similar problem. It turned out ot be the condenser.
smurph is offline   Reply With Quote
Old 11-04-2011, 09:26 PM   #10
jkeesey
jkeesey's Avatar
Sounds to me like a stuck float valve. The same thing happened to my a 2 weeks ago, tapped the carb a couple times and she's been running like a champ since.
jkeesey is offline   Reply With Quote
Old 11-04-2011, 09:36 PM   #11
Jerry in Shasta
Jerry in Shasta's Avatar
Take off the gas cap and see it that helps
JB
Jerry in Shasta is offline   Reply With Quote
