Old 08-19-2011, 05:41 PM   #1
BILLF/TRF
BILLF/TRF's Avatar
Default ignition coil question
I am installing a 6 volt alternator in my '31 tudor. It will have a negative ground. I have original wiring and i was wondering about how to hook up the "-" and "+" positive terminals of the coil. Does the black wire from the terminal box go to the "+" terminal on the coil and the red wire go to the "-" terminal or is it the opposite? Thanks.
BILLF/TRF is offline   Reply With Quote
Old 08-19-2011, 06:06 PM   #2
Ray With
Ray With's Avatar
Default Re: ignition coil question
positive goes to + on the coil and - to neg.
Hotrodchat's Picture Gallery
26,000 pictures to keep you looking
Ray With is offline   Reply With Quote
Old 08-19-2011, 07:15 PM   #3
BILLF/TRF
BILLF/TRF's Avatar
So I would have to switch the wires from their original configuration (with positive ground) of black to "-" and red to "+" to the opposite when switching to negative ground?
Old 08-20-2011, 03:48 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
It's too bad all coils don't have a + and - on them. Since your's does, then it's eay to know how to connect it. Whatever battery terminal is grounded is the same polarity on the coil that goes to the points. Negative battery ground means - on coil goes to the points.
Old 08-20-2011, 05:06 AM   #5
johnbuckley
johnbuckley's Avatar
A couple of years ago I got a polarity tester ( A-12116) from Snyders. Great gadget as it saves my brain getting tied in knots and you can check everyone else's wiring at the club meet and find that approx 25% have their coil incorrectly wired!
johnbuckley is offline   Reply With Quote
