08-19-2011, 05:41 PM | #1 |
ignition coil question
I am installing a 6 volt alternator in my '31 tudor. It will have a negative ground. I have original wiring and i was wondering about how to hook up the "-" and "+" positive terminals of the coil. Does the black wire from the terminal box go to the "+" terminal on the coil and the red wire go to the "-" terminal or is it the opposite? Thanks.
08-19-2011, 06:06 PM | #2 |
Re: ignition coil question
positive goes to + on the coil and - to neg.
08-19-2011, 07:15 PM | #3 |
08-20-2011, 03:48 AM | #4 |
It's too bad all coils don't have a + and - on them. Since your's does, then it's eay to know how to connect it. Whatever battery terminal is grounded is the same polarity on the coil that goes to the points. Negative battery ground means - on coil goes to the points.
08-20-2011, 05:06 AM | #5 |
