Old 08-14-2011, 04:07 PM   #1
Dennis/CT
Default starter band question
A while back I read about the letter and number stamped in the starter band to determine the year of the starter.Is this post still around? I think it was a chart showing the info.
Dennis/CT is offline   Reply With Quote
Old 08-14-2011, 04:38 PM   #2
Joop
Joop's Avatar
Default Re: starter band question
They are on the generator and starter band.
The new judging standards have them.
Joop is offline   Reply With Quote
Old 08-14-2011, 05:24 PM   #3
RonC
RonC's Avatar
Here's the current list of date codes
http://www.plucks329s.org/pdf/studie...ND%20CODES.pdf
RonC is offline   Reply With Quote
Old 08-15-2011, 01:41 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
J = 1929
K = 1930
L = 1931
The number is the month 10 = October, 3 = March.
Old 08-15-2011, 06:12 AM   #5
Joop
Joop's Avatar
The JS states that all bands had numbers.??
Sorted a box with about 30 in it and only 2 had letters/numbers
Steve Plucker refuted this also.
Old 08-15-2011, 08:34 AM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
There were three basic band designs. The first was smooth on both ends. The second had two locating dimples stamped on each end. The third type had one dimple on each end. The first type is common with no date code as many were produced prior to the code requirement. The third type is fairly common with no code as it appears it was dropped in mid 1932. We've not been able to find the second type with no code. I was confident I had one as it appeared unmolested. I stripped it and found that not only was it there but it was a deep stamping.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 08-15-2011, 02:27 PM   #7
Joop
Joop's Avatar
Thanks for the added info Marco
