12-14-2014, 09:25 AM | #1 |
metal tire stems
In my haste to get the 23 canopy express moving, I mounted 4 old Riverside tires with new metal valve stem tubes on my clincher rims. But I forgot to install the bridge washer and nut on the stem first. What will happen if I leave them out and run the truck? Thanks
Model A Ford Club of New Jersey http://www.mafcnj.org Model A Pick Up Owners and Enthusiasts https://www.fordbarn.com/forum/group.php?groupid=5 |
12-14-2014, 09:43 AM | #2 |
Re: metal tire stems
Keep the inflation up and likely not much will happen.
The bridge washer is used to lock the stem to the rim, keeping it from intense bending and weakening or breaking the stem with loss of pressure. Heavy loads, heavy brake action can rock the stem in its rim hole, that washer and lock nut help to prevent that, especially with oversize rim hole where the stem can wiggle. |
12-15-2014, 07:06 AM | #3 |
